TP Link Name with New Router
Bwithers1976
I have a couple of TP Link Internet over power WiFi repeaters that have not taken the name of my new plus net router so the house has two separate WiFi names and password. Its really annoying as phones don't switch over very well depending where you are in the house.
How can I change the names of the TP Link extenders? Or do I need to change the plus net router to the extenders name and password to solve it.
I hope the above makes sense.
Thanks in advance
Bryce
11 REPLIES 11
Bwithers1976
Re: TP Link Name with New Router
The TP Link extender is one of these
TP-Link AV600 Powerline Adapter Wi-Fi Kit, Wi-Fi Booster/Hotspot/ Extender, Wi-Fi Speed up to 300Mbps, 2+1 Ethernet Ports, No Configuration Required, Wi-Fi Auto-Sync, UK Plug (TL-WPA4220 KIT)
https://amzn.eu/d/60GAsyG
Fixes: 387
@Bwithers1976 Factory reset the repeaters - it should then be possible to pick up the new Hubs' details.
@Bwithers1976
if you know the IP Address of the wifi repeater you can log in using a browser
select Advanced >Wireless Settings
HTH
Bwithers1976
Thanks for the reply. I have hit the reset button at the bottom of the extender and it doesn't reset. I have downloaded the utility software for tp link but reset 'fails' message appears.
Bwithers1976
Thanks for the reply. There is no ip address on the label. Just a tp link code and a wireless password. But I can't figure out how to use the TP Link code to get into a place where a password can be entered.
the IP Address would have been allocated by the router.
Which app have you installed tpPLC ?
On the left the is an option to add a new device, does this work? You'll need the password of the powerline plug
It is recommended to use a wired connection
This might help you
https://static.tp-link.com/2019/201909/20190926/7106508500_TL-WPA4220%20KIT_QIG_V1.pdf
Bwithers1976
So I have two extenders that are av600 and they are ganging up and sharing the same name after reset and pairing. They are not taking on the plus net router name. Can I change the plus net name and password to the av600 and have one WiFi network?
Yes, you can do that if required, as previously mentioned logon to each device using a browser like firefox or google chrome.
Come back if you get stuck
Dan
Edit if you have a Hub Two look at My Devices on the home page for the IP Address of each one
Fixes: 480
@Bwithers1976
 Have you used them with the same SSID as the hub successfully before?
If both SSIDs are registered to a device and they don’t automatically switch when you move from the range of one to the other I’m slightly sceptical that they will swap even with the same SSID. The two wireless networks are not meshed and I can imagine it causing more problems than it resolves.
Bwithers1976
OMG I did it!
I got the ip addresses from the list under the router and changed the name and password of the extenders.
Thank you everyone!
Evety day is a learning day. 😀
This depends on the proximity of the wireless stations to each other, if the signal is weak then the wifi device should pick up the strongest signal.
I've had mixed results cloning or having a second SSID with a wireless extender, the conclusion I came to was to have one SSID.
Where smart devices are used it would be essential to have one SSID as it would result the device having to be reconfigured every time it is moved if it (smart device) only supports one wireless network name.
Dan
