TG585v8 router unable to access LAN shared drives & printers
PamWest
Got a problem with the TG585 Thompson router, hoping someone can help:
Setup:
3 x Latops 2 x Win7  1 x WinXP all wireless access to router
1 x Desktop WinXP with USB printer attached (which is shared) wireless access to router
1 x Media Center - Vista 64 bit wireless access to router
Routers  Thompson TG585v8 &  Netgear DGN3500 (not using both routers at same time)
All machines are DHCP enabled (to allow for switching between routers if 1 fails)
All machines have WPA+WPA2 encryption
Problem:
With <i>Netgear DGN3500</i> router can access everything on the WAN & LAN including a desktop shared printer, can also remote access all the Laptops/Pc's no problems
With <i>Thompson TG585v8</i> router can access everything on WAN, but nothing on LAN, consequently no-one can print remotely
Try to ping local pc with TG585 router and get:
Pinging 192.168.1.69 with 32 bytes of data:
Reply from 192.168.1.100: Destination host unreachable.
192.168.1.100 being my laptop
It seems that it's ONLY when I connect the Media Center to the network that I seem to lose the LAN access to all the other machines in the house,
but ALL the computers (including the Media Center) can access the WAN
The Netgear router I've always had, the Thompson router was sent by Plusnet
Any help would be appreciated, thank you
james26
Re: TG585v8 router unable to access LAN shared drives & printers
Hi I had this problme when plus sent me a new router in Jan... To solve... Go out and buy a nce new netgear adsl router!
PamWest
Quote from: james26
James26,  I'm to assume you got the same problem as me when connecting a Vista machine to your LAN too?
So is it the Vista machine at fault or the Thompson router, if it's the Thompson router, then does anyone know how to enable ICMP withing the Thompson router, I know how to telnet into the router, but just need the point of change details plz Smiley
Btw, I've already got a Netgear DGN3500 router, which I had prior to joininn PN Smiley
Fixes: 9
On a couple of PCs could you open a command prompt (Start, Run, cmd) and run the following
ipconfig /all
and post the output here please.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Vip3r
I notice that all of your computers are wireless. On my Netgear router there is an option for Wireless isolation, when this is turned on it stops all wireless devices seeing each other, it could be there is such an option on the Thomson?
Can you connect 2 of them by LAN cable and test to see that they can then see each other and if a wireless device can see a wired one?
saguaro
Have you tried updating the firmware?
http://community.plus.net/library/hardware/how-to-upgradedowngrade-the-firmware-on-the-thomson-585v7...
I had a similar problem -- though in my case the computers would be able to see each other for an hour or three after restarting the wireless -- and updating to the 8.7.8 firmware seems to have fixed it.
You do need to be able to make a wired connection to the router to do this, but it's a fairly painless process.
PamWest
Quote from: Vip3r
The problem seems to be ONLY occuring when I connect the Vista media center to the LAN, prior to this connection I can see and ping ALL the machines on the LAN, but as soon as the Vista machine connects to the LAN, then I can't ping or see any other machines on the LAN.
PamWest
Quote from: saguaro
I'm using TG585v8 version 8.2.7.7
Tried to upgrade to 8.2.7.8, but failed 3 times, even after power recycling, posted comment to Jo @ PN
PamWest
Quote from: jelv
ipconfig /all
PN Forum won't let me attach .XT files, so have to paste output here Sad
Ipconfig /all details - 1 from my laptop Win7 Professional , the other from the Media center Vista Ultimate SP 2 ; both 64 bit OS
Laptop:
Windows IP Configuration
  Host Name . . . . . . . . . . . . : Laptop-PC
  Primary Dns Suffix  . . . . . . . :
  Node Type . . . . . . . . . . . . : Hybrid
  IP Routing Enabled. . . . . . . . : No
  WINS Proxy Enabled. . . . . . . . : No
  DNS Suffix Search List. . . . . . : lan
Wireless LAN adapter Wireless Network Connection:
  Connection-specific DNS Suffix  . : lan
  Description . . . . . . . . . . . : Intel(R) WiFi Link 5100 AGN
  Physical Address. . . . . . . . . : 00-21-5D-9E-CB-26
  DHCP Enabled. . . . . . . . . . . : Yes
  Autoconfiguration Enabled . . . . : Yes
  Link-local IPv6 Address . . . . . : fe80::b49b:f7e3:5a19:23b7%15(Preferred)
  IPv4 Address. . . . . . . . . . . : 192.168.1.64(Preferred)
  Subnet Mask . . . . . . . . . . . : 255.255.255.0
  Lease Obtained. . . . . . . . . . : 07 March 2011 09:54:08
  Lease Expires . . . . . . . . . . : 08 March 2011 10:36:33
  Default Gateway . . . . . . . . . : 192.168.1.254
  DHCP Server . . . . . . . . . . . : 192.168.1.254
  DHCPv6 IAID . . . . . . . . . . . : 201335133
  DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-73-30-CA-00-23-8B-0E-59-DC
  DNS Servers . . . . . . . . . . . : 192.168.1.254
  NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Wireless Network Connection 2:
  Media State . . . . . . . . . . . : Media disconnected
  Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter
  Physical Address. . . . . . . . . : 00-21-5D-9E-CB-27
Ethernet adapter Bluetooth Network Connection:
  Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
  Physical Address. . . . . . . . . : 00-21-86-BC-B8-6F
Ethernet adapter Local Area Connection:
  Description . . . . . . . . . . . : Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)
  Physical Address. . . . . . . . . : 00-23-8B-0E-59-DC
Tunnel adapter isatap.lan:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
  Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
  DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
  Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
  IPv6 Address. . . . . . . . . . . : 2001:0:c612:107:38fb:2acd:3f57:febf(Preferred)
  Link-local IPv6 Address . . . . . : fe80::38fb:2acd:3f57:febf%14(Preferred)
  Default Gateway . . . . . . . . . : ::
  NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{2EF096D5-2D24-4FC8-B8E4-A5AC5D7901F9}:
  Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Media Center:
  Host Name . . . . . . . . . . . . : MediaPC
  Physical Address. . . . . . . . . : 00-0A-3A-7C-19-AA
  Description . . . . . . . . . . . : Realtek RTL8187 Wireless 802.11b/g 54Mbps USB 2.0 Network Adapter
  Physical Address. . . . . . . . . : 00-C0-02-0C-94-94
  Link-local IPv6 Address . . . . . : fe80::f566:7158:c54d:232f%9(Preferred)
  IPv4 Address. . . . . . . . . . . : 192.168.1.70(Preferred)
  DHCPv6 IAID . . . . . . . . . . . : 218152962
  DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-C9-43-99-00-30-1B-A0-56-02
  DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                      fec0:0:0:ffff::2%1
                                      fec0:0:0:ffff::3%1
  Description . . . . . . . . . . . : Generic Marvell Yukon Chipset based Ethernet Controller
  Physical Address. . . . . . . . . : 00-30-1B-A0-56-02
Tunnel adapter Local Area Connection* 6:
  Description . . . . . . . . . . . : isatap.{B753A5B3-DA10-41C3-A521-B655154E9E7A}
Tunnel adapter Local Area Connection* 7:
  Description . . . . . . . . . . . : isatap.{830EFAC0-8F6D-4B6C-8E01-EC11BD00AEFF}
Tunnel adapter Local Area Connection* 9:
  Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Tunnel adapter Local Area Connection* 13:
  Description . . . . . . . . . . . : isatap.{11BE1B75-9CE8-4AC8-BEB6-892F221C8F5F}
Fixes: 9
I wondered if it was because the two routers were using different subnets and you were using fixed IP addresses as I suspected the two routers might be defaulting to different subnets. However all looks good in those results with everything being consistent on 192.168.1.nnn
One other thought have you got any firewall rules set up to specify your LAN subnet, if so do they match?
PamWest
Quote from: jelv
Haven't setup any firewall rules, on the Netgear it's easy to get to the rules settings, but impossible on the Thompson, that's I'd asked if anyone has any ideas on how I can adjust the settings via Telnet Smiley
Fixes: 9
I was thinking of rules on PC firewalls - e.g. ZoneAlarm.
PamWest
No, none of the pc's have any firewalls individually as such, all have AVG guards installed, which the status of which I used to check before when I could access the drives by mapping them and checking the logs, but with the Thompson router that's impossible now also Sad
The firmware update on this router solves a problem that Vista has with these routers, there is an alternative fix for Vista (to make it behave like XP instead of requiring the DHCP Broacast flag): http://support.microsoft.com/kb/928233 , I'd recomend you try this.
Call me 'w23'
PamWest
Thanks for the link Walker I'll try this, with regards to the firmware UG, I tried it 3 times the other day, but it kept failing, have sent details to Jo at Tech Supp, who is going to have it upgraded remotely and see if that works Smiley,  I wish PN would switch their router suppliers to NG instead, they're a much better routers imo Smiley, but NG's off-shore support is really terrible tho :-(
