TG585v8 - changing the DNS server IP addresses
loungehake
I am able to change the DNS server IP address with the TG585v7 but that procedure does not seem work with the TG585v8.
I would be glad to be pointed to the appropriate procedure for the TG585v8.
Thanks.
1 REPLY
Fixes: 67
Re: TG585v8 - changing the DNS server IP addresses
The same procedure as for the v7 should work, as noted in the last comment added to the guide.
If you are trying to delete an existing setting you might need to use the flush command as noted.
David
