TG585v7 - use just as a router
- TG585v7 - use just as a router
11-12-2012 5:03 PM
I have been looking for a simple 4 port router to put behind my tv to plug the TV, Sky box. I will run an ethernet cable to my main router. They are not as easy to find these days I noticed and the prices were not cheap unless you buy some dodgy brand that is likely to cause your house to catch fire overnight.
I was wondering if it is possible to use an old TG585v7 by turning the wifi off and stopping it issuing IP addresses.
cheers
cheers
Message 1 of 6
(1,098 Views)
5 REPLIES 5
Re: TG585v7 - use just as a router
11-12-2012 5:06 PM
You want a simple switch not a router - they can be got for around £5
Here's a cheap one: http://www.ebuyer.com/132456-tenda-5-port-10-100-switch-s105
Message 2 of 6
(520 Views)
11-12-2012 6:03 PM
Cheers jelv. Until I can get hold of one though can I use my old router?
Message 3 of 6
(520 Views)
11-12-2012 6:16 PM
Yes....if it's DHCP server is disabled.
Message 4 of 6
(520 Views)
11-12-2012 6:23 PM
Thats what I thought but didnt want to start messing about for someone to come along later and tell me it was never possible LOL
Message 5 of 6
(520 Views)
11-12-2012 6:31 PM
You probably want to disable the Wifi as well, to stop it possibly interfering with any wifi from the main router.
Message 6 of 6
(520 Views)
