TG585v7 uPnP configured 'off' or so I thought
- TG585v7 uPnP configured 'off' or so I thought
22-04-2011 10:54 AM
I do not pay games, so have no need of uPnP. This morning I looked at the Router's Event log, and there several uPnP entries.
I had disabled the option yesterday, but this morning it was showing enabled.
I had one resync in the night. I cannot conceive that the router would have uPnP enabled by default, so that after every disconnection one has to reconfigure.
Am I wrong, or what is the cure?
(For the router, not me, that is ;D)
Message 1 of 4
(1,449 Views)
3 REPLIES 3
Re: TG585v7 uPnP configured 'off' or so I thought
22-04-2011 11:28 AM
yes as far as my router tg585v8 is set upnp is on as default , i have it off and after a reboot it stays off
Message 2 of 4
(384 Views)
22-04-2011 3:13 PM
Well, mine certainly isn't behaving like that. At resync or even dropped PPP it seems to default to enabled.
Message 3 of 4
(384 Views)
26-04-2011 10:24 AM
Hi Lucerne,
I had the same issue and have been doing some digging and found out the plusnets routers are auto configure using TR69. I havent tried this yet but you can turn off the auto configuration of your router (https://portal.plus.net/my.html?action=myconnection - look at automatic hardware setup).
This might solve your problem!? let me know how you get on
Message 4 of 4
(384 Views)
