TG585v 8 (8.2.77) & Windows 8
- TG585v 8 (8.2.77) & Windows 8
12-01-2013 12:28 PM
Hi
We have just got a Windows 8 laptop and I need some help getting it connected to the internet. My first problem is with the wired network. I can get to the router home page OK but I can not get internet access. Can anyone help me ? My experience with Windows 8 is limited, not with other versions of Windows nor Linux though so please be gentle with me. Is my router compatible with Win 8 ?
Message 1 of 5
(933 Views)
4 REPLIES 4
Re: TG585v 8 (8.2.77) & Windows 8
12-01-2013 12:33 PM
The router doesn't really care about the operating system so this is a Window 8 problem.
Perhaps I should move this to the Windows board but let's see what develops
Try this http://ww2.cox.com/residential/centralflorida/support/internet/article.cox?articleId=2431aa40-1d50-1...
Message 2 of 5
(585 Views)
12-01-2013 12:47 PM
thanks i tried that steps on your link but it makes no difference. My problem looks the same as when I set up linux machines and the adapter doesn't get the DNS ip from DHCP. I can't see where to check and enter it though
Message 3 of 5
(585 Views)
12-01-2013 12:50 PM
If it is a DNS or IP address problem try this http://support.zen.co.uk/kb/Knowledgebase/Broadband-Changing-IP-address-and-DNS-Server-Settings-on-W...
Message 4 of 5
(585 Views)
12-01-2013 12:58 PM
thanks oldjim, giving it a fixed IP and specifying the DNSs worked. Now to get the wireless adapter set up ! EDIT in case anyone else has this problem, my machines work with their IP given by the router but they needed the fixed DNS IP
Message 5 of 5
(585 Views)
