TG585 DHCP DNS settings
- TG585 DHCP DNS settings
29-04-2012 12:21 PM
I have a TG585v7. I also have a server on my internal network that runs a DNS server that serves up names for my local statically-defined IP addresses. I need to access this DNS server from clients that don't (and can't) have static settings, so I have to have the DHCP server send that DNS server as the only DNS server address (if there are other DNS servers sent, they will reply NXDOMAIN for my internal addresses).
I have configured the router thus:
However the config that clients get does not have the right DNS server info:
Any ideas how to stop this damned thing sending itself as the first DNS server?
Quote {admin}=>dhcp server pool config
name = LAN_private
[state] = enabled
[allocation] = dynamic
[intf] = LocalNetwork
[index] =
[poolstart] = 192.168.1.160
[poolend] = 192.168.1.199
[netmask] = 24
[gateway] = 192.168.1.254
[server] = 192.168.1.254
[primdns] = 192.168.1.2
[secdns] = 192.168.1.2
[dnsmetric] = 0
[primwins] = 192.168.1.2
[secwins] =
[leasetime] = 86400
[renewtime] =
[rebindtime] =
[unnumbered] = disabled
[localgw] = disabled
[localdns] = enabled
Quote DHCP info:
ipaddr 192.168.1.164
gateway 192.168.1.254
netmask 255.255.255.0
dns1 192.168.1.254
dns2 192.168.1.2
DHCP server 192.168.1.254
lease 86400 seconds
Message 1 of 3
(1,228 Views)
2 REPLIES 2
Re: TG585 DHCP DNS settings
29-04-2012 12:37 PM
If you run
from here, what does it list for the DNS servers?
Alex
EDIT: Just noticed the '[localdns] = enabled' line. Have you tried disabling this?
Further Reading found this:
dns server route list(on telnet)
Alex
Quote from: Paul03 TO get it to stop handing out it's own ip as primary DNS you need to use the CLI command:
dns server config state disable
If you want it to hand out local IP addresses in a range other than 192.168.1.x you need to go to the page in the screenshot below and add the appropriate range.
Message 2 of 3
(426 Views)
29-04-2012 1:32 PM
Thanks, that seems to have done the trick. (Needed to be 'false' rather than 'disabled' on the end -- guest they've updated it a bit since that was written).
Message 3 of 3
(426 Views)
