TG582n wireless reliability
- TG582n wireless reliability
11-10-2014 10:51 PM
ARP scanning often reveals results from only the router, local SSH connections are being timed out very frequently with machines seemingly becoming unreachable, I've never known anything like it.
Re: TG582n wireless reliability
12-10-2014 11:24 AM
R.
12-10-2014 3:58 PM
12-10-2014 11:00 PM
Our Homehub (ex-BT customers) never did this. I'm tempted to go back to the Homehub and see what happens.
No issues other than that.
UPDATE
As I was posting this it did its "red light of doom" hence requiring a reboot....
12-10-2014 11:17 PM
I'll keep the Technicolor as a back up methinks
13-10-2014 2:06 PM
What is it I need to look for in an alternative to know it'll work with FTTC? (I don't want to daisy chain even via ethernet off the TG582n as I'm short on power sockets).
14-10-2014 9:17 AM
Thanks for the feedback.
@Jonell77
Have you seen my reply to you here? http://community.plus.net/forum/index.php/topic,132782.msg1160655.html#msg1160655
Have a look it might help.
08-11-2014 12:27 PM
If the router has a modem, what's the point of the Openreach box?
08-11-2014 12:31 PM
08-11-2014 12:31 PM
See http://forum.kitz.co.uk/index.php?topic=14436.0
08-11-2014 12:36 PM
Quote from: _Adam_Walker_ Hi again,
If you're using a VDSL router (i.e one with a built in modem) you don't need to use the Openreach box.
Ah, so if using the Openreach box I can use any router?
10-11-2014 9:32 AM
The router would need to be able to establish a PPPoE connection in order to connect.
11-11-2014 8:57 PM
12-11-2014 9:26 AM
