TG582n wireless connection issues
- TG582n wireless connection issues
22-05-2012 12:46 PM
I recieved my new router this morning and thought all was well until I tried to connect via my wifes smartphone (Samsung Galaxy Ace Plus). Every time we try to connect it comes up with the following message:
LOGIN wireless station [mac address] can't get authorized.
I don't want to start messing about with Telnet just yet as I'm in the middle of trying to get my connection fixed (hence the replacement router) and there was another topic dealing with this that seems to have been solved at the phones end:
http://community.plus.net/forum/index.php/topic,103745.0.html
(instructions for Android: http://www.mmo-champion.com/threads/1115779-Android-Phone-Wont-Connect-to-Wifi?p=16427497)
It's now working but I'd like to know if this is a firmware fault at the phones end or the router. I've not yet tried the phone on another wireless network to find out if static IP will be an issue, if not then all good but if so it would be nice to get it fixed.
Just on a similar vein, would I see any advantage to upgrading to the IPv6 firmware once my connection issues are sorted?
Thanks, Dave
Thanks, Dave
Message 1 of 3
(2,654 Views)
2 REPLIES 2
Re: TG582n wireless connection issues
22-05-2012 1:12 PM
Quote LOGIN wireless station [mac address] can't get authorized.
Hmm sounds for some reason like the router is set up for MAC address authentication and isn't liking your wife's phone for some reason.
Quote I don't want to start messing about with Telnet just yet as I'm in the middle of trying to get my connection fixed (hence the replacement router) and there was another topic dealing with this that seems to have been solved at the phones end:
I'm not 100% sure so I'll ask our resident expert and get back to you.
Quote Just on a similar vein, would I see any advantage to upgrading to the IPv6 firmware once my connection issues are sorted?
Not really, but I doubt there would be any harm, again I'll ask and let you know
Message 2 of 3
(653 Views)
22-05-2012 3:08 PM
Message 3 of 3
(653 Views)
