TG582n telnet commands to reset connection stats?
- TG582n telnet commands to reset connection stats?
26-08-2014 1:42 PM
Re: TG582n telnet commands to reset connection stats?
26-08-2014 1:52 PM
In what way do you think your "phone" might be generating errors? Do you mean the phone itself or do you mean when you makes / receive calks?
If you dial 17070 option 2 do you hear noise on the line? If you do, you might as well just get on and report a line fault.
Does npr's website have any commands to do what you want? See http://NPR.me.uk
Kevin
26-08-2014 1:54 PM
you could set up User defined graphs in Routerstats to monitor it which is much easier to see what is happening
26-08-2014 2:09 PM
I did consider that as an option, but you can only look at one error counter at a time... It might though be enough!
It is a bit of a sledge hammer but it is very useful.
Gus,
If you take this option, configure the graph to plot changes since last sample - thus makes the error increment much more apparent.
Kevin
26-08-2014 2:12 PM
26-08-2014 2:15 PM
I did unplug my phone last night after having a connection for about 15 hours and the error rate didn't increase as much as it had for the previous 15 hours. So to rule it out I will leave an online radio stream active without and then with my phone plugged in to compare the results. So being able to reset the stats without a reboot would help.
26-08-2014 2:21 PM
With the profile of the described problem, using RouterStats would also indicate if REIN is present. So all round a really beneficial approach.
Kevin
26-08-2014 4:18 PM
Uptime: 0 days, 0:42:11
Error Seconds (Local/Remote): 298 / 0
FEC Errors (Up/Down): 58 / 4.570.434
CRC Errors (Up/Down): 0 / 7.639
HEC Errors (Up/Down): 0 / 9.614
That is way too many for 40 mins, now trying without, but looks like Argos is getting a visit tomorrow
26-08-2014 4:25 PM
26-08-2014 4:34 PM
edit: and again just now, time to phone and see if anyone is running tests
editmk2: BT booked as my connection is quickly dying, in last hour its lost sync about 8 times
27-08-2014 10:58 AM
Nothing on your or Zens status page about it
edit: just checked to see if a phone line migration had been sneaked in my another provider and no closed tickets for the last 30 days
