TG582n telnet command to remove another
- Re: TG582n telnet command to remove another
28-11-2013 1:41 AM
I had to use :connection bind application=CONE(UDP) port= to fix strictnat linked to one game and said game has just patched its network code to supposedly fix the problem.
So now I want to remove that setting and see if its really fixed or still required. So what is the telnet command for it?
FTTP 500 regrade from Tues 28th November
Message 1 of 2
(491 Views)
1 REPLY 1
28-11-2013 2:39 AM
Couldn't swear to it, but as above with UNBIND perhaps?
Message 2 of 2
(274 Views)
