TG582n runs very hot
- TG582n runs very hot
13-08-2012 7:20 PM
Measured at 51degrees C on outside bottom of case.
This seems a reliability issue and a fire hazard, is this normal?
Chris
Re: TG582n runs very hot
13-08-2012 7:54 PM
No it's certainly not normal. Mine's been running 24/7 for months, and is just barely warm.
Sure there is no way that the ventilation holes at the top could have become blocked?
13-08-2012 8:07 PM
Chris
13-08-2012 9:49 PM
14-08-2012 9:18 AM
17-08-2012 2:13 PM
Still seems high to me given that's the outside temperature. The components must be even hotter.
Chris
17-08-2012 2:23 PM
18-08-2012 7:32 AM
19-08-2012 6:25 PM
Might ambient temperature have some effect on such matters?
20-08-2012 4:16 PM
@lucerne - Yes it will, but only in that you'll never get anything to run cooler than the ambient temperature unless you have some sort of active cooling (probably a bit overkill for a router, I will admit).
20-08-2012 4:41 PM
20-08-2012 4:50 PM
My mum will have to wait a little longer for a new router.
Pete
20-08-2012 10:20 PM
Quote from: BRABUS Some components inside you pc can run in excess of a couple of hundred degrees - quite scarey really.
A bit of an exaggeration unless you have some remarkable technology in your PC Brabus
There aren't any silicon ICs which will operate at over 200 degrees (C). The normal specification is around 125 degrees absolute maximum and generally they will be running a long way below that - usually 70 degrees is a good safe limit. Still pretty hot of course and able to burn your finger but unlikely to start a fire.
There do seem to be a few reports of hot-running TG582ns for some reason. Mine is sitting on the flat top of a wooden cupboard and although it's a bit warm I wouldn't call it hot even on the underside. It feels as though 1 or 2 of the chips might be quite warm but the case itself is (I'd guess) maybe around 40-45 degrees or so.
20-08-2012 10:27 PM
