TG582n running at 5.5mbps on 802.11n
dmshowe
I've recently signed up to plusnet and got this router as part of the connection package. It is running at 5.5mbps over wifi and I can't seem to work out why. I've browsed these forums and can't see any obvious thing which would explain it. If I telnet in and look at the config I get:
{admin}=>wireless ifconfig
Admin State             : enabled
Oper State              : enabled
Network name (SSID)     : PlusnetWireless793613
Public network (any)    : enabled
Band                    : 2.4GHz
Channelwidth            : 20 MHz
Channel                 : 1 [auto]
RTS Threshold           : 2347
Short Retry Limit       : 7
Long Retry Limit        : 4
Beacon Period           : 100
Rate                    : 5.5 Mbps
Interoperability        : 802.11b/g/n
Frame Aggregation       : ampdu
Protection              : auto
Protection Mode         : ctstoself
Protection Trigger      : local&overlap
Shortslot               : auto
Framebursting           : enabled
Regulatory Domain       : Europe
Rate Set                : 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54
Dtim interval           : 3 (every 300 msec)
BSSID                   : 9c:97:26:79:36:13
Interference Mode       : auto
Interference ChannelList: 1 2 3 4 5 6 7 8 9 10 11 12 13
Short Guard Time        : disabled
Cyclic Delay Diversity  : disabled
Space Time Block Coding : disabled
Restrict N Rates in WEP/TKIP mode : enabled
I've tried setting the radio settings to:
wireless radio channelwidth=20 sgi=disabled
but no obvious outcome and certainly no change in speed. The firmware looks up to date running 10.2.2.B and the only client is connected using 802.11n
Any suggestions on what might be the problem?
19 REPLIES 19
ejs
Aspiring Hero
Fixes: 25
Re: TG582n running at 5.5mbps on 802.11n
Does the wireless client report the same 5.5Mb rate?
What actual speed do you get over the wireless?
dmshowe
Yes, it fluctuates between 2 and 5mb if I watch the network connection properties.
dmshowe
Also, I tested the same device against a friends WiFi 802.11n network and got in excess of 30mb speeds, so my suspicions are with the Technicolor gateway.
HairyMcbiker
All Star
Fixes: 21
I had same, with ONE android device 2M away from the router 5.5Mb.
Pitiful is not the word I would use.
I posted a list of the wifi round here earlier, lots of BT & a couple of TT routers. I get a STRONGER signal from the BT router across the road in the NEXT room than I did from the 582.
The 589 is a bit better in that it can hold 56Mb which is almost acceptable.
Fixes: 160
This router can be tweaked to do better - see http://NPR.me.uk
ejs
Aspiring Hero
Fixes: 25
The problem is consistent with a poor wireless signal. Besides trying different channels, you could try changing the position or orientation of the router. A 582n might just about balance vertically on its side.
dmshowe
Thanks, I doubt it is a signal strength problem. I have the thing right next to my machine and have tried in all kinds of positions to see if there is a difference. Townman, I'm not totally savvy with all the info on that site. Anything you suggest to try tweaking to improve things?
Jaggies
Might be worth looking for updated drivers for your wireless adaptor.
Pettitto
Fixes: 5
I would suggest trying for an update on your Wireless Card (drivers). Do you have any other electronic devices located close to the router?
HairyMcbiker
All Star
Fixes: 21
Seriously. Update the drivers on the unit. What if there is NO updates.
There have been MULTIPLE complaints about the PP wifi on these devices for YEARS now.
With it in the SAME position, SAME channel it gives me wifi B speed compared to the 589.
Maybe in an open field test it delivers but in a normal congested house it is just a waste of electric if you want to use wifi.
Fixes: 160
You do have the option of buying something different.  No one forces you to use the ISP offered router.  It is quite adequate for most peoples requirements.  As I've reported before, I covered most of a country pub with a TG582n.
HairyMcbiker
All Star
Fixes: 21
Quote from: Townman
Quote from: Hairy
How many wifi networks were around the county pub? Not many I would bet.
Maybe it is a "free" router but it still doesn't work well. Many people DON'T know the difference you can get from a better router, even a HH3 has better wifi and you can get them on freecycle! I know I got one there.
dmshowe
My network drivers are up to date. I've also tried with a few other devices during testing to eliminate potential card issues and the issue remains. I've checked channels and there is no conflict with neighbourhood network channels. To me, it looks like the router is defaulting to a low rate. I've also restarted the router on a number of occasions during testing.
Pettitto
Fixes: 5
Do you see an improvement, out of interest with your router away from your PC (anything else electrical)?
