TG582n running at 5.5mbps on 802.11n
- Re: TG582n running at 5.5mbps on 802.11n
18-05-2014 4:35 PM
Quote {admin}=>wireless ifconfig
Admin State : enabled
Oper State : enabled
Network name (SSID) : PlusnetWireless793613
Public network (any) : enabled
Band : 2.4GHz
Channelwidth : 20 MHz
Channel : 1 [auto]
RTS Threshold : 2347
Short Retry Limit : 7
Long Retry Limit : 4
Beacon Period : 100
Rate : 5.5 Mbps
Interoperability : 802.11b/g/n
Frame Aggregation : ampdu
Protection : auto
Protection Mode : ctstoself
Protection Trigger : local&overlap
Shortslot : auto
Framebursting : enabled
Regulatory Domain : Europe
Rate Set : 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54
Dtim interval : 3 (every 300 msec)
BSSID : 9c:97:26:79:36:13
Interference Mode : auto
Interference ChannelList: 1 2 3 4 5 6 7 8 9 10 11 12 13
Short Guard Time : disabled
Cyclic Delay Diversity : disabled
Space Time Block Coding : disabled
Restrict N Rates in WEP/TKIP mode : enabled
I've tried setting the radio settings to:
Quote wireless radio channelwidth=20 sgi=disabled
but no obvious outcome and certainly no change in speed. The firmware looks up to date running 10.2.2.B and the only client is connected using 802.11n
Any suggestions on what might be the problem?
18-05-2014 4:52 PM
What actual speed do you get over the wireless?
18-05-2014 5:44 PM
18-05-2014 5:47 PM
18-05-2014 5:51 PM
Pitiful is not the word I would use.
I posted a list of the wifi round here earlier, lots of BT & a couple of TT routers. I get a STRONGER signal from the BT router across the road in the NEXT room than I did from the 582.
The 589 is a bit better in that it can hold 56Mb which is almost acceptable.
18-05-2014 5:52 PM
18-05-2014 6:15 PM
18-05-2014 8:42 PM
19-05-2014 2:01 AM
19-05-2014 9:31 AM
19-05-2014 9:44 AM
There have been MULTIPLE complaints about the PP wifi on these devices for YEARS now.
With it in the SAME position, SAME channel it gives me wifi B speed compared to the 589.
Maybe in an open field test it delivers but in a normal congested house it is just a waste of electric if you want to use wifi.
19-05-2014 9:56 AM
19-05-2014 10:00 AM
Quote from: Townman I covered most of a country pub with a TG582n.
Quote from: Hairy in a normal congested house it is just a waste of electric if you want to use wifi.
How many wifi networks were around the county pub? Not many I would bet.
Maybe it is a "free" router but it still doesn't work well. Many people DON'T know the difference you can get from a better router, even a HH3 has better wifi and you can get them on freecycle! I know I got one there.
19-05-2014 12:38 PM
19-05-2014 12:48 PM
