TG582n router
- Re: TG582n router
TG582n router
10-01-2013 10:13 AM
Have just switched over from Madasafish to Plusnet and am connected as expected via existing Netgear DG834GT router, syncing at 5248kbps. This is only possible on my 20CN long rural line by manipulating the SNR margin via telnet to access the CLI. So, is it possible to do the same thing with the supplied TG582n router and if so, can anyone please point me in the right direction as to how?
Message 1 of 5
(960 Views)
4 REPLIES 4
Re: TG582n router
10-01-2013 10:38 AM
You don't actually need to change routers unless you need to. (The old one failing etc)
Message 2 of 5
(317 Views)
Re: TG582n router
10-01-2013 1:44 PM
Yes, you are quite right of course but the Netgear router is not an N class device whilst the TG582n is. That would be the advantage.
Message 3 of 5
(317 Views)
Re: TG582n router
10-01-2013 2:06 PM
As far as I'm aware you can't tweak target noise margin ratio with the TG582n.
David
Message 4 of 5
(317 Views)
Re: TG582n router
10-01-2013 4:51 PM
Ah! That is a shame, looks like I wasted £5.99 on delivery of a router I will not be able to make use of.
Message 5 of 5
(317 Views)
