TG582n - editing 192.168.1.253 IP address query - Resolved
bill888
Seasoned Pro
Fixes: 21
Resolved:
Saving the configuration as an INI, editing the INI and restoring is the way to do it if this is your main router.
Alternatively, I have observed if you disable DHCP on the TG582n and edit/delete the LAN_private dhcp pool, the TG582n will seek out another DHCP server on the LAN to get an IP address to assign to the USB port.
I now have the surplus TG582n set up as a dedicated print server connected to my existing LAN.
