TG582n dropping ASDL connection
- TG582n dropping ASDL connection
Re: TG582n dropping ASDL connection
24-03-2015 6:26 PM
Copper Test Details
A to E B to E
Capacitance: 264 NanoFarad 265 NanoFarad
DP Line Length Estimate: 2881 Metres DN Line Length Estimate: 2938 Metres
Celerity: 39.1 dB Line Loss: 46.61 dB
Line Stability: Stable
Fault Report Advised: N
Service Level: 2
24-03-2015 6:29 PM
24-03-2015 6:33 PM
24-03-2015 6:56 PM
24-03-2015 7:10 PM
With regard to these pings, what level are they going up to? A quick glance at the RS Log should tell you.
You can adjust the Ping Graph scale at the top of the graph - Y-axis max.
24-03-2015 7:40 PM
max =1000
min=21
ave=158
most are in the range 22 to 33 highest (non 1000) is around 200.
I have just returned to my pc after a while away and find that I have had 3 linestate down episodes; they were at 17:10, 17:31 and 18:22.
I have attached some charts and the last part of the syslog is below
<37> Mar 24 15:10:34 LOGIN User rstats logged in on [HTTP] (from 192.168.1.67)
<102> Mar 24 15:19:41 SNTP Synchronised again to server: 212.159.13.49
<81> Mar 24 15:20:39 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 119.1
78.25.45 Dst ip: 80.229.143.132 Type: Destination Unreachable Code: Port Unreach
eable
<81> Mar 24 16:14:43 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 113.1
30.159.192 Dst ip: 80.229.143.132 Type: Destination Unreachable Code: Port Unrea
cheable
<102> Mar 24 16:19:42 SNTP Synchronised again to server: 212.159.13.49
<37> Mar 24 16:21:06 LOGIN User rstats logged in on [HTTP] (from 192.168.1.67)
<81> Mar 24 16:22:11 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 84.20
2.33.48 Dst ip: 80.229.143.132 Type: Destination Unreachable Code: Port Unreache
able
<81> Mar 24 16:28:51 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 179.9
6.40.30 Dst ip: 80.229.143.132 Type: Time Exceeded Code: Time to Live exceeded i
n Transit
<81> Mar 24 16:59:37 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 212.2
02.156.49 Dst ip: 80.229.143.132 Type: Destination Unreachable Code: Port Unreac
heable
<37> Mar 24 17:05:44 LOGIN User rstats logged in on [HTTP] (from 192.168.1.67)
<173> Mar 24 17:10:14 xDSL linestate down
<85> Mar 24 17:10:14 FIREWALL event (1 of 1): created rules
<85> Mar 24 17:10:14 FIREWALL event (1 of 1): modified rules
<173> Mar 24 17:10:32 xDSL linestate down
<132> Mar 24 17:10:57 PPP link down (Internet) [80.229.143.132]
<173> Mar 24 17:11:02 xDSL linestate down
<173> Mar 24 17:11:28 xDSL linestate up (ITU-T G.992.5; downstream: 7467 kbit/s,
upstream: 1199 kbit/s; output Power Down: 20.4 dBm, Up: 12.6 dBm; line Attenuat
ion Down: 41.5 dB, Up: 22.8 dB; snr Margin Down: 9.1 dB, Up: 6.4 dB)
<38> Mar 24 17:11:32 PPP CHAP Receive challenge from rhost bras-red11.pe (Intern
et)
<38> Mar 24 17:11:32 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 24 17:11:33 PPP CHAP Receive success (Internet)
<85> Mar 24 17:11:36 FIREWALL event (1 of 2): deleted rules
<85> Mar 24 17:11:36 FIREWALL event (1 of 1): created rules
<85> Mar 24 17:11:36 FIREWALL event (1 of 1): modified rules
<132> Mar 24 17:11:36 PPP link up (Internet) [80.229.143.132]
<102> Mar 24 17:19:42 SNTP Synchronised again to server: 212.159.13.49
<81> Mar 24 17:27:37 FIREWALL icmp check (1 of 2): Protocol: ICMP Src ip: 37.18
7.35.182 Dst ip: 80.229.143.132 Type: Destination Unreachable Code: Port Unreach
eable
<173> Mar 24 17:31:07 xDSL linestate down
<85> Mar 24 17:31:07 FIREWALL event (1 of 1): created rules
<85> Mar 24 17:31:07 FIREWALL event (1 of 1): modified rules
<173> Mar 24 17:31:24 xDSL linestate down
<132> Mar 24 17:31:47 PPP link down (Internet) [80.229.143.132]
<173> Mar 24 17:31:54 xDSL linestate down
<173> Mar 24 17:32:20 xDSL linestate up (ITU-T G.992.5; downstream: 7410 kbit/s,
upstream: 1192 kbit/s; output Power Down: 20.4 dBm, Up: 12.7 dBm; line Attenuat
ion Down: 41.5 dB, Up: 22.8 dB; snr Margin Down: 9.1 dB, Up: 6.2 dB)
<38> Mar 24 17:32:21 PPP CHAP Receive challenge from rhost bras-red11.pe (Intern
et)
<38> Mar 24 17:32:22 PPP CHAP Receive challenge from rhost JUNOS (Internet)
<38> Mar 24 17:32:22 PPP CHAP Receive success (Internet)
<85> Mar 24 17:32:25 FIREWALL event (1 of 2): deleted rules
<132> Mar 24 17:32:25 PPP link up (Internet) [80.229.143.132]
<85> Mar 24 17:32:25 FIREWALL event (1 of 1): created rules
<85> Mar 24 17:32:25 FIREWALL event (1 of 1): modified rules
<81> Mar 24 17:49:19 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 185.1
9.142.242 Dst ip: 80.229.143.132 Type: Destination Unreachable Code: Port Unreac
heable
<81> Mar 24 17:53:47 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 211.1
10.232.254 Dst ip: 80.229.143.132 Type: Destination Unreachable Code: Port Unrea
cheable
<81> Mar 24 18:14:05 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 42.22
6.228.115 Dst ip: 80.229.143.132 Type: Destination Unreachable Code: Port Unreac
heable
<102> Mar 24 18:19:42 SNTP Synchronised again to server: 212.159.13.49
<173> Mar 24 18:22:10 xDSL linestate down
<85> Mar 24 18:22:10 FIREWALL event (1 of 1): created rules
<85> Mar 24 18:22:10 FIREWALL event (1 of 1): modified rules
<173> Mar 24 18:22:21 xDSL linestate down
<132> Mar 24 18:22:54 PPP link down (Internet) [80.229.143.132]
<173> Mar 24 18:24:11 xDSL linestate down
<173> Mar 24 18:24:42 xDSL linestate down
<173> Mar 24 18:25:08 xDSL linestate up (ITU-T G.992.5; downstream: 7184 kbit/s,
upstream: 1180 kbit/s; output Power Down: 20.4 dBm, Up: 12.8 dBm; line Attenuat
<38> Mar 24 18:25:12 PPP CHAP Receive challenge from rhost bras-red11.pe (Intern
et)
<38> Mar 24 18:25:12 PPP CHAP Receive challenge from rhost PCL-AG01 (Internet)
<38> Mar 24 18:25:12 PPP CHAP Receive success (Internet)
<85> Mar 24 18:25:12 FIREWALL event (1 of 2): deleted rules
<85> Mar 24 18:25:12 FIREWALL event (1 of 1): created rules
<85> Mar 24 18:25:12 FIREWALL event (1 of 1): modified rules
<132> Mar 24 18:25:12 PPP link up (Internet) [80.229.143.132]
<81> Mar 24 18:40:09 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 177.2
1.102.129 Dst ip: 80.229.143.132 Type: Destination Unreachable Code: Port Unreac
heable
<37> Mar 24 19:00:37 LOGIN User admin logged in on [HTTP] (from 192.168.1.67)
<37> Mar 24 19:02:47 LOGIN User rstats logged in on [HTTP] (from 192.168.1.67)
<37> Mar 24 19:06:56 LOGIN User admin logged in on TELNET (192.168.1.67)
{admin}=>
24-03-2015 8:21 PM
If you get a point where you can add that you are getting a repetitive gradual increase/decrease in the DS SNRM - periodicity varying slightly but around 12-15 minutes, and the Upstream SNRM is very noisy and you can hear a very slight hum using the phone, that may help. If that doesn't happen during raising the ticket, than go back to it and use the "add information" bit.
I think Tony may have a look at it.
24-03-2015 8:30 PM
I'll get it done tonight as I'm out tomorrow until later on
25-03-2015 8:43 PM
Here is latest RouterStats page . . . OUCH
Uptime: 0 days, 23:44:07
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,193 / 6,595
Data Transferred (Sent/Received) [MB/MB]: 62.95 / 242.49
Output Power (Up/Down) [dBm]: 12.7 / 0.0
Line Attenuation (Up/Down) [dB]: 22.8 / 41.5
SN Margin (Up/Down) [dB]: 5.3 / 10.1
Loss of Framing (Local/Remote): 34 / 0
Loss of Signal (Local/Remote): 4 / 0
Loss of Link (Remote): - Error Seconds (Local/Remote): 90,329 / 0
FEC Errors (Up/Down): 8,476 / 342,603,096
CRC Errors (Up/Down): 3,204,152 / 5,277,778
HEC Errors (Up/Down): 2,945,118 / 2,198,753
25-03-2015 10:30 PM
25-03-2015 10:37 PM
Hopefully Tony does have it.
25-03-2015 11:40 PM
Question #101451491
26-03-2015 7:21 AM
SN Margin (Up/Down) [dB]: 28.0 / 11.6
Most recent routerstats attached
26-03-2015 8:03 AM
26-03-2015 10:29 AM
