TG582n dropping ASDL connection
andyw
Product Name: TG582n
Serial Number: <snip>
Software Release: 8.4.4.J
Software Variant: BV
Boot Loader Version: 1.0.5
Product Code: 3701603B
Board Name: DANT-T
I frequently lose connection to the internet and normally have to reset my router; on today's event log I have several instances of the following message:
FIREWALL replay check (1 of 2): Protocol: ICMP Src ip: 92.2.200.13 Dst ip:
80.229.143.132 Type: Destination Unreachable Code: Host Unreacheable.
Please see attached copy of event log.
I note that there is a later version of firmware available; can you please consider this as part of your response?
jim:green Serial number removed as this is also the login password mod:end
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: TG582n dropping ASDL connection
When you lose connection to the internet what happens to the lights on the router? Does the ADSL light go off or flicker? Does the Internet light stay lit and green?
There is a new version of the firmware, it can be found here along with the update tool: http://products.plus-payh.co.uk/firmware/
 Chris Parr
 Plusnet Staff
andyw
Both lights are out.
Thanks for the firmware info: I will wait for your response before updating.
Fixes: 21
Do you have any audible noise on your on your phone line?
andyw
No noise; it has always been very clear.
Fixes: 21
Can you log into the 582n and copy and paste the full DSL Stats - including error figures.
andyw
I have appended 2 error logs:
one is that first submitted on 20 Feb with errors generated while network was in use
the second is for today; I was away all weekend and logged in at approx 17:45 when I returned home.
You asked "Can you log into the 582n and copy and paste the full DSL Stats - including error figures."
I can only find error logs; if you need other info I will need guidance to location please.
andyw
andyw
I just found these stats:
DSL Connection
Link Information
Uptime: 2 days, 2:25:46
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.201 / 7.837
Data Transferred (Sent/Received) [MB/MB]: 169,84 / 611,80
Output Power (Up/Down) [dBm]: 12,6 / 0,0
Line Attenuation (Up/Down) [dB]: 22,7 / 41,0
SN Margin (Up/Down) [dB]: 5,7 / 3,1
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1.804 / 0
FEC Errors (Up/Down): 1.284 / 6.808.439
CRC Errors (Up/Down): 57 / 740
HEC Errors (Up/Down): 45 / 5.762
Fixes: 21
Ah excellent those stats were just what were needed.  The downstream is under performing. The cause may also what's causing the drops
I'll post a bit later when I'm not on my mobile.
Can you describe what sockets you have and what's plugged in where.
andyw
ASDL V 1.0 box
TG582n connects directly to data socket
DECT base unit connects directly to phone socket
There is an ethernet connection between the TG582n and a Belkin USB hub
Fixes: 21
If you are about more than an hour before dusk, can you post some daytime TG582n Full DSL stats
andyw
Stats at 15:50
DSL Connection
Link Information
Uptime: 0 days, 5:31:42
Bandwidth (Up/Down) [kbps/kbps]: 1.197 / 8.788
Data Transferred (Sent/Received) [MB/MB]: 8,56 / 19,95
SN Margin (Up/Down) [dB]: 6,0 / 3,2
Error Seconds (Local/Remote): 79 / 0
FEC Errors (Up/Down): 0 / 1.349.393
CRC Errors (Up/Down): 50 / 172
HEC Errors (Up/Down): 32 / 2.080
andyw
stats at 17:04 - I hope these are useful
DSL Connection
Link Information
Uptime: 0 days, 6:46:07
Data Transferred (Sent/Received) [MB/MB]: 9,93 / 25,18
SN Margin (Up/Down) [dB]: 5,7 / 2,8
Error Seconds (Local/Remote): 108 / 0
FEC Errors (Up/Down): 0 / 1.720.323
CRC Errors (Up/Down): 95 / 210
HEC Errors (Up/Down): 118 / 2.355
Fixes: 21
Well done, yes they are very useful. Had the modem/router been switched of at all and switched on around 1020 this morning or rebooted perhaps?
Other than that do you have an open fault ticket?
Are you prone to power dips/cuts at all?
The stats suggest that your are on a 3dB Target SNRM, so certainly previously, the exchange DLM (Dynamic Line Management) doesn't think you have severe issues to put you on a 3dB Target. The current Downstream sync speed is nearly 1Mbps better than previously which suggests the previous resync occurred when there was some "noise" (may or may not be audible) when that resync occurred. The current error levels are a bit higher than one would like to see but not out of the way.
We'll see if CRT could post a Visual Radius log.
If you could post some more stats say an hour or so after dark.
