TG582n config not usable from Internet Explorer 10
- TG582n config not usable from Internet Explorer 10
17-10-2012 5:21 PM
When I try to access the router config page, several problems, which seem to be Windows 8/Internet Explorer 10 related.
Firstly, after entering admin/[myPassword] it takes around 90 seconds before the router homepage is displayed. If I do the same on XP or Windows 7, I get the same page in a couple of seconds.
More importantly, none of the links on the 'Technicolor Gateway Homepage' work. Clicking on them has no effect. Again, if I do the same on an XP or Win7 PC, the links work as expected.
I wondered if it was a java issue as I didn't have a JRE installed on the Win8 box, but I don't have it installed on the XP or Win7 boxes either, and they work fine. I did try installing JRE both 32b and 64b, but still get a slow login and no links work.
Any suggestions gratefully received.
Mark
Re: TG582n config not usable from Internet Explorer 10
17-10-2012 5:55 PM
17-10-2012 6:03 PM
17-10-2012 6:36 PM
I'm not going to change my browser, or my o/s; I just want help on how to get the router config page to work with my current setup. Hadn't realised it was necessary to spell out something so obvious when asking a question, but I am a newbie.
17-10-2012 6:42 PM
Just downloading and installing either will allow you to view the pages FAST.
17-10-2012 7:05 PM
17-10-2012 7:19 PM
As stated, I'm not, under any circumstances, going to change my browser so please don't tell me to. If you posted a problem encountered under Linux/firefox, I doubt you would welcome a response that told you to switch to a different browser!
I am simply asking for help with getting the router page working with W8/IE10. That must be possible.
17-10-2012 7:26 PM
I have tried Chrome on several occasions and even alternative browsers but keep returning to FF.
You stated that you had issues with IE I merely suggested you try an alternative but YOU are being very dismissive, SO NO MORE INPUT FROM ME HELP YOURSELF !. (IF you can)
17-10-2012 7:32 PM
Well I haven't got W8 or IE10, so I can't help!
17-10-2012 7:42 PM
Is "Compatibility View" enabled in IE10? IE8 (and IE9?) used to automatically enable this for local/intranet addresses, unless certain headers were set on the pages (or it can be disabled globally in the browser).
17-10-2012 9:04 PM
Compatibility View - good thought but unfortunately that didn't make any difference.
17-10-2012 9:06 PM
are using the metro ie 10 or the normal one ?
17-10-2012 9:36 PM
i'm on a demo firmware of 10.02b (which shouldn't matter). but both the metro ui ie 10 and normal one works .
I would suggest you try resetting your ie defaults .
17-10-2012 10:03 PM
Strange.
I'll throw a clean (MAPS) Win8 onto a spare PC and see how that pans out...
p.s. I was running from Desktop, not 'Metro'
18-10-2012 12:03 AM
Clean install of W8Ent demo worked fine with the router home page.
Back to my every-day PC W8Pro and after much faffing I did a reset to defaults on IE10 and that got it working.
Many, many thanks taras for pointing me in the right direction..
I've got a sneaking suspicion I may have set some over-zealous security settings but I couldn't spot them to un-set.
1 box incautiously ticked, or unticked... many hours wasted.
