TG582n and Linksys WRT160N - bridge issues
andymaw11
I'm new to plusnet and the router supplied (tg682n) is a bit of a disappoint. I understand it's basic but the wireless signal won't even reach from one side of the flat to the other (about 12 metres away!). I want to use the router just a modem bridging to my old Linksys WRT160N.
I tried following the instructions on these 2 threads but I feel I'm missing something somewhere as it's not working. http://community.plus.net/forum/index.php/topic,105753.0.html/ and http://community.plus.net/forum/index.php/topic,112320.0.html/
Could someone possibly take me through a quick step by step of how to do this?
These are the telnet commands which do seem to have changed the router to a bridge but nothing is showing up on the linksys router.
:ppp flush
:atm flush
:atm  phonebook flush
:atm phonebook add name pvc_Internet addr 0*38
:atm ifadd intf atm_Internet
:atm ifconfig intf atm_Internet dest pvc_Internet ulp mac encaps llc
:atm ifattach intf atm_Internet
:eth bridge ifadd intf Internet brname bridge
:eth bridge ifconfig intf Internet dest atm_Internet
:eth bridge ifconfig intf Internet wan enabled
:service system modify name DHCP-S state disabled
:system config upnp disabled
:saveall
Hope you can help
21 REPLIES 21
Fixes: 395
Re: TG582n and Linksys WRT160N - bridge issues
You'll need to set the Internet connection Type on the WRT160N to PPPoE and input your PlusNet username/password details.
andymaw11
I did that, then checked the status page and there was nothing, no ip address etc.
Fixes: 395
Looking at your telnet commands in detail there is an eth bridge ifattach intf=InterNet missing.
From this thread http://community.plus.net/forum/index.php/topic,105753.0.html here is the list ( some names changed from your list )
ppp relay flush
eth flush
atm flush
ppp flush
atm phonebook flush
atm phonebook add name=BrPPPoE_ph addr=0.38
atm ifadd intf=BrPPPoE_atm
atm ifconfig intf=BrPPPoE_atm dest=BrPPPoE_ph  encaps=vcmux ulp=mac
atm ifattach intf=BrPPPoE_atm
eth bridge ifadd intf=BrPPPoE_br
eth bridge ifconfig intf=BrPPPoE_br dest=BrPPPoE_atm
eth bridge ifattach intf=BrPPPoE_br
saveall
andymaw11
Thanks for that, I'll give it a whirl later.
Cheers
andymaw11
That gave me an error message I'm afraid. Where should I type that command that you said was missing?
Also should it have : before each command. On the flushes they flag up an error without the :
Fixes: 395
After the - eth bridge ifconfig intf Internet dest atm_Internet
Probably but I've never noticed any difference with or without
Might be best to do a factory reset and start again from scratch.
andymaw11
Apologies for being a bit thick with this but I'm now confused.
What should the whole thing look like?
Sorry!
Fixes: 395
Try
:ppp flush
:atm flush
:eth bridge ifattach intf InterNet
:saveall
Kelly
Fixes: 9
Quote from: andymaw11
That sounds very weird.
Is it an open flat?  Or lots of solid walls?
Kelly Dorset
Ex-Broadband Service Manager
andymaw11
Mister W - Thanks for the response. All works fine up to - :eth bridge ifattach intf InterNet which tells me that:
Invalid interface name.
Bad value for parameter 'intf InterNet'
Unknown command.
Kelly - There's one pretty heavy duty wall to get through. The signal sometimes is fine, sometimes not. Particularly, the wireless printer is the struggle. Signal dips out a lot.
orbrey
Hi, suspect the issue there is the capital N - just a guess, but it might be case sensitive. Try it with a lower case n and see if that works?
andymaw11
Starting to tear my hair out now! Went through those steps and plugged in the other router - told me unable to get ip address from pppoe
I'm out of ideas
PAPED
The set-up might be right, I have a similar set-up (different equipment but same logic) and it can take 5 to 10 minutes of trying to connect before you get an IP address over PPPoE via the bridged modem showing on the router....
I would suggest just from my own experience that you set it and leave it for 10 minutes or so to see if it does connect.... and you "might" be surprised 🙂
Fixes: 395
Thanks Matt, looks like it's my turn for a bad day today Embarrassed
That's interesting, I thought the delay was only on fttc. I guess there's not very many people use pppoe on an adsl connection.
