TG582n and Linksys WRT160N - bridge issues
- Re: TG582n and Linksys WRT160N - bridge issues
09-06-2013 10:40 AM
I'm new to plusnet and the router supplied (tg682n) is a bit of a disappoint. I understand it's basic but the wireless signal won't even reach from one side of the flat to the other (about 12 metres away!). I want to use the router just a modem bridging to my old Linksys WRT160N.
I tried following the instructions on these 2 threads but I feel I'm missing something somewhere as it's not working. http://community.plus.net/forum/index.php/topic,105753.0.html/ and http://community.plus.net/forum/index.php/topic,112320.0.html/
Could someone possibly take me through a quick step by step of how to do this?
These are the telnet commands which do seem to have changed the router to a bridge but nothing is showing up on the linksys router.
:ppp flush
:atm flush
:atm phonebook flush
:atm phonebook add name pvc_Internet addr 0*38
:atm ifadd intf atm_Internet
:atm ifconfig intf atm_Internet dest pvc_Internet ulp mac encaps llc
:atm ifattach intf atm_Internet
:eth bridge ifadd intf Internet brname bridge
:eth bridge ifconfig intf Internet dest atm_Internet
:eth bridge ifconfig intf Internet wan enabled
:service system modify name DHCP-S state disabled
:system config upnp disabled
:saveall
Hope you can help
09-06-2013 12:17 PM
09-06-2013 12:44 PM
09-06-2013 1:02 PM
From this thread http://community.plus.net/forum/index.php/topic,105753.0.html here is the list ( some names changed from your list )
Quote ppp relay flush
eth flush
atm flush
ppp flush
atm phonebook flush
atm phonebook add name=BrPPPoE_ph addr=0.38
atm ifadd intf=BrPPPoE_atm
atm ifconfig intf=BrPPPoE_atm dest=BrPPPoE_ph encaps=vcmux ulp=mac
atm ifattach intf=BrPPPoE_atm
eth bridge ifadd intf=BrPPPoE_br
eth bridge ifconfig intf=BrPPPoE_br dest=BrPPPoE_atm
eth bridge ifattach intf=BrPPPoE_br
saveall
09-06-2013 3:30 PM
Cheers
12-06-2013 7:35 AM
Also should it have : before each command. On the flushes they flag up an error without the :
12-06-2013 8:13 AM
After the - eth bridge ifconfig intf Internet dest atm_Internet
Quote Where should I type that command that you said was missing?
Probably but I've never noticed any difference with or without
Quote Also should it have : before each command
Might be best to do a factory reset and start again from scratch.
12-06-2013 9:18 AM
What should the whole thing look like?
Sorry!
12-06-2013 9:27 AM
Quote :ppp flush
:atm flush
:eth bridge ifattach intf InterNet
:saveall
12-06-2013 9:46 AM
Quote from: andymaw11 Hi,
That sounds very weird.
Is it an open flat? Or lots of solid walls?
Ex-Broadband Service Manager
12-06-2013 11:14 AM
Invalid interface name.
Bad value for parameter 'intf InterNet'
Unknown command.
Kelly - There's one pretty heavy duty wall to get through. The signal sometimes is fine, sometimes not. Particularly, the wireless printer is the struggle. Signal dips out a lot.
12-06-2013 11:58 AM
12-06-2013 1:26 PM
I'm out of ideas
12-06-2013 1:43 PM
I would suggest just from my own experience that you set it and leave it for 10 minutes or so to see if it does connect.... and you "might" be surprised 🙂
12-06-2013 3:30 PM
Thanks Matt, looks like it's my turn for a bad day today
Quote Hi, suspect the issue there is the capital N
That's interesting, I thought the delay was only on fttc. I guess there's not very many people use pppoe on an adsl connection.
Quote I would suggest just from my own experience that you set it and leave it for 10 minutes or so to see if it does connect
