TG582n + Mac VPN (L2TP)
- TG582n + Mac VPN (L2TP)
04-09-2013 10:46 PM
I have configured the ports to forward (500, 1701, 4500) from the internet to my mac. As far as I can see this is exactly the same as my old O2 router config - yet I can't make a VPN connection while I'm roaming. I don't even get logs on the router about the connection attempt...?
It works when I assign the mac to the DMZ - but I'm sure I don't want this a a solution.
So, my questions are:
- should port-forwarding be enough to enable the VPN?
- do I need to configure the router via the command line (I read other posts that talk of unbinding stuff? but these don't seem to be the same type of VPN)
- do I need to use the DMZ - don't really want this...
Many thanks,
Derek
Edit: my firewall is turned off in the plus.net firewall config.
Many thanks,
Derek
Message 1 of 3
(1,678 Views)
2 REPLIES 2
Re: TG582n + Mac VPN (L2TP)
05-09-2013 8:06 AM
Quote do I need to configure the router via the command line (I read other posts that talk of unbinding stuff? but these don't seem to be the same type of VPN)
IPSec is commonly used in association with L2TP so I would suggest trying the unbind of ike & esp
Message 2 of 3
(372 Views)
05-09-2013 2:57 PM
Thanks MisterW!
I'll try that when I get back.
Message 3 of 3
(372 Views)
