TG582n Internet light showing red
- TG582n Internet light showing red
01-02-2013 5:08 PM
I received a Technicolour TG582n router from plusnet, and all appaers to be working OK, but the internet light is showing a constant red light.
Apparently this means my conection has failed but it appears to be working fine at the moment.
any pointers on what the red light means?
Message 1 of 3
(763 Views)
2 REPLIES 2
Re: TG582n Internet light showing red
01-02-2013 5:14 PM
If you search for 582 & red light you will see there are a couple of threads on it.
As long as you have a connection ignore it.
Message 2 of 3
(425 Views)
04-02-2013 11:02 AM
I've just checked and can't see any issues with your connection so I'd not worry too much but obviously do let me know if you have any concerns.
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13599757111988.png"/><
Message 3 of 3
(425 Views)
