TG582n Firmware
- TG582n Firmware
- « Previous
- 1
- 2
- Next »
Re: TG582n Firmware
26-03-2013 10:43 AM
Quote from: barkeyo DEMO ONLY - Plusnet - ADSL - TG582n (without USB port) - 10.2.2.B
this is the version that I installed on my router last night
Thanks. Has it helped?
Message 16 of 19
(521 Views)
Re: TG582n Firmware
26-03-2013 11:14 AM
Too early to tell yet with regards to the wireless signal, but I also made the following modifications suggested by npr earlier in the thread.
http://products.plus-payh.co.uk/firmware/
wireless radio cdd=enabled
wireless radio stbc=enabled
Initial feeling is that the signal is marginally stronger and more stable, but I'll need to really put it through its paces over the next 24 hours or so and see. What the new software clearly does have is some additional options for configuring the device for Fibre (if or when you upgrade) and what looks like some fixes in terms of DCHP handling of IP leases. I'd suggest that primarily this is a release designed to combine the current seperate versions used depending on whether you opt for fibre or ADSL when you sign up, but with some additional fixes and improvements thrown in for good measure. Whether it'll ever be any better than simply getting a better router is probably open for discussion.
Message 17 of 19
(521 Views)
Re: TG582n Firmware
26-03-2013 1:25 PM
Hi Barkeyo
People don't write post to the forums when their router works ; )
I wouldn't go by how many bars you get on your client device. Can you do a speedtest and let us know how you get on? Or better still do you have a machine you could use as an iPerf server? Happy to help you with this - I'm not aware of how technical you are.
I'm still looking for routers that don't work as expected so that I can send to Technicolor for analysis.The two I have sent them came back as being OK.
Definitely you are not going to get 76Mb/s if the signal has to pass through walls or other sources of interference. I'm not aware of a 2.4GHz, 2x2 router that gets around this any better. The difference in the firmware (ADSL demo version only so far) is that it checks more often that you are on the best channel using a pretty sophisticated algorithm. Remember there are really only 3 useable channels in this band: 1, 6, 11 and Inssider etc can tell you which other wi-fi routers are around, not how much they are being used or how well they are behaving.
The Thompson we used before had half the wireless performance that the 582n has. I don't have a 587v2 but it had 2 external antennas so you could move them around to improve the directionality independently of each other. That might have helped. I don't have one or I would do a comparison.
We are more than willing to send you an other 582n though if we can get yours back to test?
Best regards,
Graham
Best regards,
Graham
Message 18 of 19
(521 Views)
Re: TG582n Firmware
26-03-2013 1:58 PM
Quote from: Graham21 The Thompson we used before had half the wireless performance that the 582n has. I don't have a 587v2 but it had 2 external antennas so you could move them around to improve the directionality independently of each other. That might have helped. I don't have one or I would do a comparison.
I only upgraded last week so I still have the 585 v7 which definitely had better WiFi performance. Is that of any interest? It has a single external antenna.
Message 19 of 19
(521 Views)
- « Previous
- 1
- 2
- Next »
