TG582n - Event log
ledders
TG582n - Event log
Does anybody know if there is any way of being able to increase the size of the event log on the Technicolor TG582n?
I was hoping it was going to be able to store events for a number of days, but it only appears to store events for a few hours.
Fixes: 6
Re: TG582n - Event log
Viewing the log via telnet may give a longer retention, the log can even survives a reboot.
Alternatively you could send the log to a syslog client running on your PC.
This may help: http://npr.me.uk/telnet.html#syslog
Fixes: 10
Another option: Install and run RouterStats to monitor the router - it includes an option to view the full telnet log.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
ledders
Thanks for the replies so far.  I tried the telnet command and I was able to see further back.
I wouldn't know where to start with regards to the syslog suggestion.  Is this quite easy to set up?
Fixes: 6
Yes it is easy to set up, you just need to download and install a syslog client on a pc and send the following two telnet commands to the router:
syslog config activate=enabled
syslog ruleadd fac=all sev=debug dest=192.168.1.67
Change the IP address above to match that of the PC running the syslog.
You can fine tune what is sent to the syslog but that gets more complicated.
Fixes: 10
That's the easy bit!
How about some instructions on how to set up a syslog server on Wndows?
Fixes: 6
Quote from: jelv
OK:
a) Install 3CSyslog
b) Run 3CSyslog
It's that simple.  Tongue
Provided the previously mentioned telnet commands have been issued to the router and a software firewall is not blocking access  between router and 3CSyslog the program will start recording the routers log.
Note: telnet command to stop the router sending the log:
syslog config activate=disabled
Fixes: 10
Where do you get that from? I can't find it on any source I'd trust.
The top hit from a Google search gives filecrop which I've never heard of. They list the source of the software as http://www.allrussian.info/index.php?page=Thread&postID=2166606 - I suggest you look at that to see if you'd trust it!
3Com was taken over by HP and a search on their site doesn't give any results.
Fixes: 6
Quote from: jelv
If the OP is concerned about the sources you've found he can contact me via PM.
Note:
I don't know the copyright status of that program so I have no intention of hosting it for general download.
Other syslog software is available.
Fixes: 10
I've looked in to doing this in the past and failed to find a free syslog windows package that looked easy to set up. If you can directly provide a link to software that is safe and easy to set up I for one would be grateful.
Fixes: 10
Quote from: npr
Does that need a saveall?
Fixes: 6
Yes if you need it to keep the setting after a reboot.
Let us know how things go.
davembk
I'm a router novice and was hoping to see the browser accessed event log going back at least to the point the router was powered up, so I could build up a pattern of outages, just as it says in the user guide, but like you say it only goes back a few hours which is about as useful.as a hairnet in a rainstorm.
http://help.demon.net/help-articles/troubleshooting-and-faqs/technicolor-router-support/#eventlogs
Fixes: 10
It's available via telnet or you could install Routerstats.
