TG582n DSL Firmware
ianc1990
TG582n DSL Firmware
Hi guys,
Is there any chance someone can provide the latest firmware for the TG582n?
I have seen a few posts here and there on the forum but I'm currently experiencing a few issues with my connection (already logged) and I don't have another router to test so I want to see if a firmware update helps at all - its the DSL version of the firmware I need (if its any different to the fibre firmware)
Can I also please have a link to the flashing software (as I don't think there's an option on the GUI?)
I'm currently on firmware version 8.4.4.J
On another note - has anyone tried DD-WRT on this router?  Its not officially supported so I don't want to brick it but it will be interesting if someone has given it a go!
Ian
Fixes: 162
Re: TG582n DSL Firmware
If you like we can push the new firmware out from here?
 Chris Parr
 Plusnet Staff
ianc1990
Yes please Chris - thats great
Cheers
ianc1990
Chris,
Is there also a chance you could send me the release notes on the new firmware?  It will be nice to nosey though it.
Im pretty certain my issues are wifi related now - I have just got a laptop home from work as my macbook doesn't have a LAN port and the PS3 is also dropping out (not sure why as its wired up to the router) but the laptop seems to be behaving much better than both other devices so I feel a little silly raising a fault now.
I wont ask the question there but probably create another post on some wifi advice!
I'll give our products team a nudge and get this arranged.
That's been done for you, let me know how you get on.
ianc1990
Spot on - Thanks Chris!
I see a few more options on there which is nice, I find that this router is actually quite good and functions wise, powerful but Technicolor seem to have omitted most configuration settings - if it was in the GUI, it would be on par with a draytek!
One more thing, I asked on another post whether my upload could be un-capped but I don't think its been spotted - is there any chance you can look into this for me or should I log a call for this?
Again - Thank you very much!
Fixes: 16
Here's some generic release notes from Technicolor about the 10.2 firmware: http://www.technicolorbroadbandpartner.com/getfile.php?id=7727
Hi ianc1990, that modify to uncap your upstream has been placed and should complete tomorrow morning for you Smiley
ianc1990
Thanks Matt!
Managed to enable a 6in4 tunnel with the new firmware too so big smiles at the moment!
dick:quote
Fixes: 10
Quote from: ejs
Well that perhaps explains the improved stability I've seen with the upgraded firmware:
Fixes and improvements
The ADSLx/POTS version includes fixes and improvements for following issues:
  • HLog / QLN / SATN Accuracy in ITU-T G.992.3/5 improved
  • External Noise Robustness improved.
  • Stability improved under micro-interruption events.
  • New modem option support to force fast mode solving.
  • jelv (a.k.a Spoon Whittler)
    Mobile: iD mobile (£4/month)
    ianc1990
    Hmm,
    Can anyone think of any reason why the think broadband monitor is showing so many dropped packets in the early morning (I never use my connection at this time)?
    Here is my IPv4 graph with the same result...
    Luzern
    Seasoned Pro
    Quote from: ejs
    Interesting it would be, if, for the most part,  I had a Masters in Sinoserbocrat Estonian Grin
    Oh that in internet layman's terms, someone would explain the benefits of upgrading from 8.4.4.J for the relativley unsophisticated user.
    Fixes: 16
    A few wifi improvements:
    • Better auto channel choice (better than just counting the number of other wifi networks per channel)
    • Max 11n speed increased from 130Mbps to 144Mbps
    • A couple of other improvements for a stronger / more reliable signal
    The vast number of IPv6 related changes are not currently relevant to the casual user.
    Luzern
    Seasoned Pro
    @ Matt Taylor
    If there are no likely problems, can you upgrade me too? Thanks.
