TG582n Command Line Interface (CLI) Reference Guide
edpgc
Hi
Has anyone got a link to a CLI reference guide for the plusnet supplied TG582n.
Many thanks.
Ed
Fixes: 21
Re: TG582n Command Line Interface (CLI) Reference Guide
Try http://wiki.aa.org.uk/index.php/TG582N further down the page http://wiki.aa.org.uk/index.php/File:TG582n_CLI_Guide_v1.0_public.pdf but no instructions mind, it's just a list of commands  Roll eyes
Oh, and welcome to the forums. Half of that lot won't be too much use as you are Fibre mind  Smiley
Fixes: 16
There's a CLI guide for the 10.2 firmware here: http://www.speedtouch.ca/pdf/TG582n-manual.pdf
Fixes: 45
and npr has constructed a pretty good guide to the commonly used CLI commands here http://npr.me.uk/telnet.html
Fixes: 5
There's some cli reference guides here, they have been extracted from the router by Alex (the site owner).
They are the ones ending with "v2.0.pdf.7z", the advantage is they also show hidden commands.
http://download.modem-help.co.uk/mfcs-A/Alcatel/Modems/TG582n/v1/Manuals/CLI-Reference/
Luzern
Seasoned Pro
gatecrashing! IIRC there is one that allows event logs to be retained longer for viewing. Can someone point me to it, please?
Razer
I wish I could find one to dump the log to text file on my computer.
Fixes: 21
@lucerne
Do you mean get a fuller log from telnet? - syslog msgbuf show hist=enabled
Fixes: 5
Quote from: Razer
http://npr.me.uk/telnet.html#syslog
You haven't look very hard Wink
Razer
Yeah, but I need to have some client running to receive it. I'd rather have the router simply write a text file to my hard drive on its own.
Fixes: 21
For the Thomson you need the following from a command prompt - make sure you are either in the directory you want to save the file, or specify the full pathname
telnet -f filename.txt 192.168.1.254
Fixes: 5
You could run a telnet script on a PC to issue Anotherone's command.
Automate it to run once every day or so, save the result and tidy up the with sed.
Good luck Wink
http://npr.me.uk/scripting.html
Razer
OK, thanks AO. I can't access your site at the moment, npr, "connection reset". I'll try again later.
Luzern
Seasoned Pro
@AO tthat's the one! Thank you!  Smiley
