TG582N Issues
bestsim
TG582N Issues
I had my Netgear replaced with a TG582N router to resolve issues with poor Wireless performance/disconnects.
The new routers has certainly been a big improvement for wireless connections.
The issue I have is I use a VPN to connect into work, and after swapping to the new router noticed
a number of apps (i.e. Lotus Notes) timing out and failing to connect . My connections to the router for the VPN
is via one of the wired ethernet ports on the TG582N.
I tried to go back to the old Netgear just to prove the issue was with the new router, but this no lnger seems to get an Internet connection.
Any one any clues on settings for the new router that may help  ?Huh
Re: TG582N Issues
Does this thread help: http://community.plus.net/forum/index.php/topic,109173.0.html ?
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
bestsim
Re: TG582N Issues
WWWombat - Many thanks for taking the time to respond to my issue. I have updated the IPSEC config settings as recommended and it looks a lot better
Cheers
Simon
