TG582 on 20CN
- TG582 on 20CN
- « Previous
- 1
- 2
- Next »
Re: TG582 on 20CN
14-12-2012 9:01 PM
I think it would be helpful if anyone else is seeing the same as me could post because that would allow further testing if we find something that works for me.
If something we try is not successful I will post so people know what doesn't work.
Re: TG582 on 20CN
14-12-2012 9:07 PM
Re: TG582 on 20CN
14-12-2012 9:55 PM
Just double checked - I was seeing what I expected.
It's actually syncing at 8128 which ties up with the BT speed test reporting it as 8.13Mbps
PS Had anyone noticed that at the bottom of the front page of http://www.speedtester.bt.com/ it says:
Quote Note : Have you tried our new BT Wholesale speed test website -www.speedtest.btwholesale.com.
Re: TG582 on 20CN
16-12-2012 10:42 AM
Uptime: 1 day, 17:39:30
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 832 / 8.128
Data Transferred (Sent/Received) [MB/GB]: 145,14 / 1,00
Output Power (Up/Down) [dBm]: 12,3 / 20,0
Line Attenuation (Up/Down) [dB]: 9,0 / 18,0
SN Margin (Up/Down) [dB]: 14,0 / 9,6
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 49 / -
FEC Errors (Up/Down): 37 / 12.930
CRC Errors (Up/Down): 7 / 63
HEC Errors (Up/Down): - / 256
Re: TG582 on 20CN
16-12-2012 2:07 PM
I wonder if the dash values are actually negative where the TG585 used to report 4 trillion. If this applies the telnet interface (or the Routerstats stats page) show the number with a minus sign. (Negative values are obviously nonsense - presumably result from storage not being properly reset.)
You should get good speeds when you are moved to ADSL2+.
Re: TG582 on 20CN
16-12-2012 2:38 PM
What does the SNR drop to at night ?
I would also have expected a better SNR with that attenuation, I used to get 9db on 20CN on a 28db line when synched at 8128k.
Re: TG582 on 20CN
16-12-2012 2:40 PM
Re: TG582 on 20CN
16-12-2012 2:43 PM
SNR drops very little at night, maybe 0.5db (it's all underground which I guess helps).
The SNR I'm getting is very, very close to what I was getting from the Netgear before I swapped over.
Re: TG582 on 20CN
16-12-2012 2:51 PM
Quote I wish I knew what happened just after 10:35!
Wow, that's a big burst of errors ???.
That could explain the high total. Other than the burst at 10:35, the rest of the time it looks fine.
Is that the only burst during the day, and I don't suppose it's every day is it ?
Re: TG582 on 20CN
16-12-2012 2:55 PM
Re: TG582 on 20CN
16-12-2012 4:08 PM
Quote from: spraxyt ...... the FEC errors though in my experience and what I've seen posted Thomson routers seem to count these up for something to do.
Pretty much my observation
However, it would be nice to know how/when they change, so monitoring them could prove interesting. But I'd monitor the HEC errors as well and see if they change as the same time. I was a little surprised to see the HEC errors higher than the trivial level of CRC errors though. No noise on your line? You might consider a filter swap if things get interesting. See if phone usage has any effect.
Re: TG582 on 20CN
16-12-2012 5:30 PM
That discrepancy continued on migration to 21CN ADSL2+. Currently with 25 days 1 hr uptime CRC error count is 51,916, HEC error count 1,020,459 (FEC errors 60,585,756 for the record).
Re: TG582 on 20CN
17-01-2013 12:39 PM
Following the router firmware upgrade I didn't have a single further drop of sync on 20CN.
Not long after my exchange was upgraded to 21CN. Since then I've been monitoring the stats closely. I was also sent a second TG582 which has the standard 8.4.4.J firmware (in case my original problem was a hardware fault).
I'm finding the router with the 10.2.2.9 firmware will hold a higher sync rate.
Re: TG582 on 20CN
18-03-2013 10:09 AM
Re: TG582 on 20CN
18-03-2013 3:32 PM
- « Previous
- 1
- 2
- Next »
