TG582 on 20CN
- Re: TG582 on 20CN
TG582 on 20CN
12-12-2012 11:02 AM
In January we moved to Dorset. Again I got a 8192 sync with interleaving off and it never missed a beat.
Last week I swapped to a Plusnet supplied TG582. I've been seeing in it's log brief drops in sync (around every couple of hours) although there has been no loss of PPPoA and Plusnet are seeing no drops.
This morning I happened to look at my TBB Ping Graph and found this:
No prizes for guessing what has happened! I don't do gaming so I'm going to let it run and monitor if I see any ill effects. I'll also watch to see if I still get the sync drops.
Conclusion has to be that the TG582 not only is inferior for it's wireless performance, but is also inferior for it's ability to hold a good connection on an ADSL1 20CN line.
Re: TG582 on 20CN
12-12-2012 11:21 AM
Incidently, if you view the log via telnet it goes a lot further back than you can see via the standard interface.
Re: TG582 on 20CN
12-12-2012 11:40 AM
The 2700 would hold sync for months whereas the TG seems to drop most weeks.
Didn't know about the log being longer from the CLI , will have a look at that tonight.
Re: TG582 on 20CN
14-12-2012 4:31 PM
<173> Dec 12 13:47:21 xDSL linestate down
<173> Dec 12 15:31:11 xDSL linestate down
<173> Dec 12 17:10:54 xDSL linestate down
<173> Dec 12 19:05:15 xDSL linestate down
<173> Dec 12 19:51:32 xDSL linestate down
<173> Dec 12 21:43:53 xDSL linestate down
<173> Dec 12 23:29:33 xDSL linestate down
<173> Dec 13 01:13:14 xDSL linestate down
<173> Dec 13 03:07:56 xDSL linestate down
<173> Dec 13 04:51:46 xDSL linestate down
<173> Dec 13 06:37:49 xDSL linestate down
<173> Dec 13 08:28:50 xDSL linestate down
<173> Dec 13 10:32:54 xDSL linestate down
<173> Dec 13 12:11:24 xDSL linestate down
<173> Dec 13 14:09:46 xDSL linestate down
<173> Dec 13 15:46:51 xDSL linestate down
<173> Dec 13 18:59:56 xDSL linestate down
<173> Dec 13 20:51:02 xDSL linestate down
<173> Dec 13 22:46:25 xDSL linestate down
<173> Dec 14 00:36:16 xDSL linestate down
<173> Dec 14 02:40:10 xDSL linestate down
<173> Dec 14 03:28:57 xDSL linestate down
<173> Dec 14 05:08:57 xDSL linestate down
<173> Dec 14 07:08:28 xDSL linestate down
<173> Dec 14 08:54:23 xDSL linestate down
<173> Dec 14 10:33:04 xDSL linestate down
<173> Dec 14 12:36:59 xDSL linestate down
<173> Dec 14 15:06:42 xDSL linestate down
At no stage have I seen the noise margin below 8.
Has anyone any ideas what might be the cause of this other than the router being useless?
Re: TG582 on 20CN
14-12-2012 4:53 PM
Re: TG582 on 20CN
14-12-2012 5:08 PM
Re: TG582 on 20CN
14-12-2012 5:16 PM
Re: TG582 on 20CN
14-12-2012 5:56 PM
I'll contribute something to this when I can, but I've only done some brief on-line testing with the 582n (not enough to draw any conclusions) and won't be doing any more until I've managed to reconfigure it to suit my current network - the latter I've not really had the time to do with too many fingers in too many pies and various domestic commitments
Are you still syncing at 8128? and I guess you have a fixed IP address?
Re: TG582 on 20CN
14-12-2012 6:37 PM
I'm not seeing any drop in the PPPoA session (and Plusnet are not seeing the drops) so I wouldn't see a new IP even if I wasn't on a fixed IP.
Re: TG582 on 20CN
14-12-2012 7:57 PM
What was your TBB ping plot like with your Netgear?
Re: TG582 on 20CN
14-12-2012 8:09 PM
Sounds like the router is behaving rather oddly.
Re: TG582 on 20CN
14-12-2012 8:13 PM
Re: TG582 on 20CN
14-12-2012 8:15 PM
Quote from: Anotherone What was your TBB ping plot like with your Netgear?
Here's the day before I changed over - it's pretty typical.
Re: TG582 on 20CN
14-12-2012 8:35 PM
Quote from: MisterW I don't understand how you're not losing the ppp session , you would have expected the router to tear down the ppp connection automatically as soon as the DSL drops.
We have seen occasional other reports of people losing their connection which was not being seen by Plusnet and that has usually been put down to loss of a wireless connection. There is a very simple way to see if your connection is seeing the same symptoms: on the router interface got to the main Broadband Connection and look at the uptime of the DSL connection and the Internet connection. If the Internet connection is longer you have the same symptoms. Up until a recent reboot I was showing an internet connection of over a day but a DSL connection of only an hour or so.
Re: TG582 on 20CN
14-12-2012 8:44 PM
Quote from: Anotherone Does RouterStats (Lite) show this apparent sync loss?
Not sure why you think I'm running RouterStats Lite - the full blown RouterStats supports the TG582!
As the sync is down for around 15 seconds it depends upon whether RouterStats polls the router when it is down. I have it set to refresh every 30 seconds so quite frequently it does see it.
