TG582 CLI - commands to access Data Transferred
- TG582 CLI - commands to access Data Transferred
22-09-2013 8:40 PM
Does anyone know what the CLI command is to access the Data Transferred stats that are displayed in the GUI?
TIA
TIA
Message 1 of 3
(586 Views)
2 REPLIES 2
Re: TG582 CLI - commands to access Data Transferred
23-09-2013 1:43 PM
Try this command:
ip iflist
Use the TX and RX data from the Internet interface.
To match the binary GB / MB units shown in the GUI:
For MB divide by 1048576
For GB divide by 1073741824
Note:
The above is binary units ie 1K = 1024
ISP's often calculate data usage in decimal units ie 1K = 1000
I believe transfer data show by the cli command only goes up to 4 GB and then resets to zero.
There is some doubt as to the accuracy of data transfer results shown by the routers GUI and cli.
ip iflist
Note:
Message 2 of 3
(301 Views)
23-09-2013 10:08 PM
Thanks, that is a lot easier to look at that what I did pull off ....
Which was via "eth bridge list"
Message 3 of 3
(301 Views)
