TD-W8968 Router problem after losing broadband
- Re: TD-W8968 Router problem after losing broadba...
12-10-2014 1:36 PM
Re: Router problem after losing broadband
12-10-2014 1:59 PM
I'm no expert on that modem/router but there are a few around who are. I suggested edit the title (by editing your first post) to include TD-W8968 in the title.
Re: TD-W8968 Router problem after losing broadband
12-10-2014 2:07 PM
12-10-2014 2:14 PM
Either change channel in the TD-W8968 or the laptop, which ever gives you the best signal.
12-10-2014 2:23 PM
12-10-2014 2:54 PM
You may even have to delete the device wireless settings and set them up again.
12-10-2014 3:06 PM
12-10-2014 3:19 PM
12-10-2014 3:41 PM
12-10-2014 3:48 PM
12-10-2014 4:04 PM
12-10-2014 4:14 PM
12-10-2014 4:30 PM
WPS
Enable WPS:
Add Client (This feature is available only when WPA-PSK, WPA2-PSK or OPEN mode is configured)
Push-Button PIN
Help
Device PIN: Help
12-10-2014 4:35 PM
have you got a wireless security page that contain entries like:
* Disable Wireless Security
* WPA/WPA2 - Personal(Recommended)
Authentication Type: WPA2/PSK
Encryption: AES
Wireless Password: ???????
12-10-2014 4:38 PM
