TBB again more spikes
Only seems to be mine and mikehiow that show the spikes today at the same times from http://community.plus.net/ping-graphs/ at roughly 1pm 1.20pm 3.30pm 6.20pm, my router logs show no dropped PPP or sync, phone is crystal clear, currently on ptw-ag01
edit: Strat's as well, opera failed to load his graph first time
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Re: TBB again more spikes
I did a clean router reboot this morning and now on pcl-ag02 with no repeats since, but see that both Strat and mikehiow both still get them so looking like ptw-ag01 is at fault
Fixes: 81
Changed Gateway...now on pcl-ag03.
Customer and Forum Moderator.
Yaroze
Receiving stupid pings with ag6.
Tracing route to bbc.com [212.58.253.67]
over a maximum of 30 hops:
 1    <1 ms    <1 ms    <1 ms  home.gateway.home.gateway [192.168.1.254]
 2   870 ms   895 ms   742 ms  lo0-central10.pcl-ag06.plus.net [195.166.128.187
 3   574 ms   499 ms   429 ms  link-a-central10.pcl-gw01.plus.net [212.159.2.18
0]
 4   579 ms   863 ms   936 ms  xe-10-3-0.pcl-cr01.plus.net [212.159.0.212]
 5   923 ms   891 ms   929 ms  ae1.ptw-cr01.plus.net [195.166.129.0]
 6  1114 ms  1189 ms  1177 ms  212.58.239.6
 7     *        *        *     Request timed out.
 8   910 ms   904 ms   968 ms  ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
 9   543 ms   684 ms   767 ms  132.185.255.156
10     *      537 ms   439 ms  www-vip.cwwtf.bbc.co.uk [212.58.253.67]
This is just rubbish, even if it's peak time (7:40PM) I shouldn't be getting ping times of 1000.
Yes, I've rebooted the router, and I am the only one on my own network not downloading anything.
The strange thing is that ping is normal for about 2-3minutes after a connection refresh and then it goes to stupid.
I'm seriously getting fed up with this,
Edit: Another trace from google:
Tracing route to google.com [173.194.34.131]
  2  316 ms  430 ms  381 ms  lo0-central10.pcl-ag06.plus.net [195.166.128.187
  3  416 ms  391 ms  426 ms  link-a-central10.pcl-gw01.plus.net [212.159.2.18
0]
  4  444 ms  477 ms  515 ms  xe-10-3-0.pcl-cr01.plus.net [212.159.0.212]
  5  558 ms  596 ms  680 ms  ae1.ptw-cr01.plus.net [195.166.129.0]
  6  1105 ms    *      522 ms  72.14.222.97
  7  571 ms  592 ms  463 ms  209.85.240.63
  8  241 ms  307 ms  305 ms  209.85.253.115
  9  204 ms  231 ms  261 ms  lhr14s21-in-f3.1e100.net [173.194.34.131]
Trace complete.
Fixes: 162
Nothing obvious on the graphing from here. Gus, do you have a snapshot of your TBB graph from when you were having this issue? Also was it causing any problems at all?
 Chris Parr
 Plusnet Staff
29th Dec
30th
I did a reboot on 30th at 8am as I hadn't in a while and to see if it was the gateway at fault, after it no more spikes.  But both Strat and Mikehiow showed more at the same times on 30th, so that said to me they were on the same gateway. Mikehiow still showing them for yesterday at 5pm and 9.20ish pm.
As for if they affected my connection, during some of them I was watching IPlayer or channel4 player and did have the streams stall, which is why I checked my graph initially.
