turn on suggestions
Systemline and fibre install
- Systemline and fibre install
09-07-2014 8:15 PM
Hi
My telephone connection comes through my systemline box which is used for multi media
As such I don't have master socket , just the input cable terminated at the systemline box
Will the engineer be ok removing the phone line and putting in a master socket , have full access to the cable but there is also loads of Cat5 cable termination around the area
Re: Systemline and fibre install
09-07-2014 10:34 PM
I believe they have to install a master socket if there isn't one (or isn't the latest type).
10-07-2014 9:27 AM
Hi Duanedibbley,
I'm unsure what you mean by your phone line coming through your systemline box - would you be able to upload some pictures of your set up please?
I've had a look at your account and you're not due an engineer visit - is this something you would like arranging?
Has the property never had a master socket? Some more background information would be really helpful if you could provide it?
10-07-2014 9:50 AM
Quote from: Linn I've had a look at your account and you're not due an engineer visit - is this something you would like arranging?
From the topic title I'd guess he's thinking of ordering FTTC!
jelv (a.k.a Spoon Whittler) Why I have left Plusnet (warning: long post!) Broadband: Andrews & Arnold Home::1 (FTTC 80/20) Line rental: Pulse 8 Home Line Rental (£13/month) Mobile: iD mobile (£4/month) |
10-07-2014 12:41 PM
Jelv is correct
I am thinking about it currently but if is going to be a mare then I might not do it as I have to specialist out to do any jiggery pokers with the system line anyway and I don't want the engineer to decline to do anything once he gets there
Will upload some pics of the nitemare tonite
10-07-2014 5:05 PM
As promised pics of the cable nitemare
10-07-2014 5:19 PM
As the telephone comes through the systemline box I suggest you contact them initially to find out how it should be installed.
Incidently, why is it connected to the phone line? I'm surprised looking at the way it's filtered why it isn't causing issues with your ADSL.
