Syncing (sinking) at a stinking 416 kbps...
- Syncing (sinking) at a stinking 416 kbps...
- « Previous
- 1
- 2
- Next »
Re: Syncing (sinking) at a stinking 416 kbps...
10-01-2008 11:27 AM
Keep an eye on it and let me know how it behaves.
I'll never leave really...
Message 16 of 24
(450 Views)
10-01-2008 11:32 AM
NP, using Routerstats to monitor, latest version can be downloaded from http://www.vwlowen.co.uk/internet/files.htm
Lets give it 24hrs and see what happens.
Thanks DM.
Thanks DM.
KABOOM!
Message 17 of 24
(450 Views)
10-01-2008 11:38 AM
Quote from: sophos9 monkey,
I had the same type of situation when I moved, BT had to conduct a lift and shift to resolve. Your internals sound fine (adsl nation plates are good kit)
Sopos9, not heard the term 'lift and shift' before can you elaborate?
Thanks, DM.
KABOOM!
Message 18 of 24
(450 Views)
10-01-2008 11:39 AM
DM,
Your circuit is plugged into a line card at your exchange. A lift and shift is where the circuit is removed from one port on the line card and plugged into a different port, or a different line card.
Message 19 of 24
(450 Views)
10-01-2008 11:42 AM
Its simply means pulling your connection from a port/card and connecting it to a new port/card on a DSLAM, this happens if the fault is found in a exchange port/card (or if open reach dont wanna investigate further )
Message 20 of 24
(450 Views)
10-01-2008 11:42 AM
Second again
Message 21 of 24
(450 Views)
10-01-2008 11:45 AM
lol
KABOOM!
Message 22 of 24
(450 Views)
11-01-2008 9:09 AM
Right its happened again at approx 6.30pm last night sync speed gradually stepped down to 350 kbps until this morning when I hard booted the router and im syncing back at 1952 kbps
DM.
DM.
KABOOM!
Message 23 of 24
(450 Views)
11-01-2008 9:39 AM
Thanks for the update.
Are you seeing a number of connection dropouts? BT are saying that they're currently unable to see any problems on your line as such, but I can see that there have been a number of reconnections over the last couple of days, which will be when you get the lower sync speeds.
I can continue to progress this with BT however.
Message 24 of 24
(450 Views)
- « Previous
- 1
- 2
- Next »
