Syncing (sinking) at a stinking 416 kbps...
- Re: Syncing (sinking) at a stinking 416 kbps...
09-01-2008 11:06 PM
I've been quiet as connection has been solid for the last few months however yesterday evening my connection refused to sync above 416 kbps although stats remain more or less unchanged?
I left the router unplugged all night and it sync'd at the normal 1900 kbps this morning. However it's gone back to sync'ing at 416 kbps any ideas?
I've not been able to run http://speedtester.bt.com/ as it's been busy all evening! Grrr
Thanks in advance, DM.
09-01-2008 11:44 PM
Netgear DG834N (FW V1.01.06)
My gut feel is that problem is either at the DSLAM or external to my house.
DM.
10-01-2008 10:02 AM
DM.
10-01-2008 10:05 AM
James doesn't work here anymore.
Do you have anything else connected to your phoneline? Could you possibly remove *everything* except for your router and then reboot it to set what level of SNR you then see?
10-01-2008 10:36 AM
As previously stated the line is filtered at the master socket and plugged into the master socket. Additional extensions are on a seperate circuit so removing them would have no effect to my SNR.
DM.
10-01-2008 10:38 AM
If you reboot a few times, does it normally sync at ~1900Kbps or ~5000Kbps?
If it is initially syncing at ~1900Kbps and susequenmtly dropping, then it would suggest that there is a problem.
10-01-2008 10:50 AM
DM.
10-01-2008 10:55 AM
Please try again in a few minutes.'
DM.
10-01-2008 10:58 AM
DM.
10-01-2008 11:02 AM
I had the same type of situation when I moved, BT had to conduct a lift and shift to resolve. Your internals sound fine (adsl nation plates are good kit)
10-01-2008 11:05 AM
You did actually have two open tickets. You don't anymore
I've rasied your fault to BT requesting that they look into your problem. I'll pass your regards onto James.
Sophos9 - Your issue was different to an extent. DM is a long, long way from the exchange, which is probably part of the issue here.
10-01-2008 11:16 AM
Blimey, I'm some way! 57db attenuation, as the crow files I'm around 2.4km from exchange, following the lines I'm def over 2miles
10-01-2008 11:17 AM
So we're probably talking about 3 miles plus. Or 5 kilometres for those of you that like metric.
10-01-2008 11:23 AM
Hope you get it sorted!
10-01-2008 11:26 AM
I just took a shower and the router has re-sync'd to 1952 kbps... perhaps I should wash more regulary and I may get a better connection...
DM.
