Syncing at 20727, only getting 9.8 according to btw speedchecker?
- Syncing at 20727, only getting 9.8 according to bt...
29-12-2015 10:30 AM
Hi
As per the title, I am getting alot slower download rates than what I should be getting. have checked using the BT Wholesale speed checker.
This is from the router:
7 - Data rate: 1231/20727
8 - Maximum data rate: 1232/20764
9 - Noise margin: 6.2/3.0
10 - Line attenuation: 8.2/18.5
From BT Wholesale speedchecker:
Download Speed (Mbps): 9.89
Upload Speed (Mbps): 1.03
Ping Latency (ms):59
Please advise best resolution
Regards
Chris
ps account name is [mremoved]
pps, I would call the helpdesk but I currently have no voice
dick:green Full email address removed from a public forum to a private area accessible to PN staff.
Regards
Chris
Message 1 of 4
(791 Views)
3 REPLIES 3
Re: Syncing at 20727, only getting 9.8 according to btw speedchecker?
29-12-2015 11:57 AM
I can't see anything obvious that would cause the issues, your line is connecting at a good speed and the profile is set correctly.
Are the speeds you're seeing over a wired or wireless connection?
Message 2 of 4
(417 Views)
29-12-2015 9:53 PM
This is via a wired connection.
Message 3 of 4
(417 Views)
30-12-2015 11:48 AM
Can you run the BT Speedtest again but do the further diagnostics test after the first completes?
Message 4 of 4
(417 Views)
