Synch speed shows OK, actual about 15 times less
materialman
Title says it. Speeds seemed very low earlier. Router showed low. Rebooted router - improved. Now again real speeds very low though router shows OK ever after rebooting router and then PC then router again. Can anyone help please? Same if tested from a mobile phone - real speed very slow.
Uptime: 0 days, 0:06:15
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 999 / 6.479
Data Transferred (Sent/Received) [MB/MB]: 4,83 / 8,03
Output Power (Up/Down) [dBm]: 12,7 / 0,0
Line Attenuation (Up/Down) [dB]: 29,2 / 48,0
SN Margin (Up/Down) [dB]: 5,9 / 6,1
Loss of Link (Remote): -
Error Seconds (Local/Remote): 6 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 7 / 207
HEC Errors (Up/Down): 4 / 274
http://www.speedtest.net/my-result/3564032080
and now
http://www.speedtest.net/my-result/3571026375
Fixes: 67
Re: Synch speed shows OK, actual about 15 times less
Hi materialman, sorry about this. The profile needed to be updated manually, our systems hadn't quite caught up with that yet.
Any problems just let us know.
 Adam Walker
materialman
Ah your reply came through as I was typing - now OK thanks.
Uptime: 0 days, 0:04:53
Bandwidth (Up/Down) [kbps/kbps]: 975 / 6.460
Data Transferred (Sent/Received) [MB/MB]: 1,83 / 11,42
Output Power (Up/Down) [dBm]: 12,6 / 0,0
Line Attenuation (Up/Down) [dB]: 29,2 / 47,5
SN Margin (Up/Down) [dB]: 6,5 / 6,1
Error Seconds (Local/Remote): 3 / 0
CRC Errors (Up/Down): 12 / 3
HEC Errors (Up/Down): 2 / 5
And actual speed:
http://www.speedtest.net/my-result/3571135376
