Synch speed down to 1000 Kbps why?
- Re: Synch speed down to 1000 Kbps why?
07-11-2008 10:42 AM
Just out of interested I logged into the member centre to keep an eye on usage in light of the current issues and also had a look at synch speed which is down to 1000 Kbps
Router stats show the WAN link has been up for over 400 hours
Connection Status
Connection Time 401:11:36
Connecting to Server Connected
Negotiation Success
Authentication Success
Getting IP Addresses 87.112.92.xx (last octet rmoved for obvious reasons)
Getting Network Mask 255.255.255.255
Modem status
ADSL Firmware Version A2pB023b.d20e
Modem Status Connected
DownStream Connection Speed 1184 kbps
UpStream Connection Speed 448 kbps
VPI 0
VCI 38
Could a helpful PN person have a look at the connection data from your end and shed any light on what has happened?
07-11-2008 10:44 AM
Quote from: techguy Modem status
link:speed
07-11-2008 10:58 AM
Just querying as it has been happy enough between 1500 and 2000 and has just dropped all of a sudden.
Am keen to try and get any bugs squashed if I can before my exchange goes over to ADSL 2+ and I end up with a dire connection like I had on O2 which is the reason I left.
07-11-2008 11:07 AM
07-11-2008 11:10 AM
07-11-2008 11:18 AM
I bought mine from here which actually says that it is the V4 http://www.dslsource.co.uk/netgear-dg834.aspx
This is what DMT shows - note I use Routerstats for monitoring as it can create a text log which is great for history
07-11-2008 11:19 AM
07-11-2008 11:27 AM
Definitely worth getting a piece of hardware that will work with DMT to see if you can force it down to 6dB and maintain stability.
07-11-2008 11:30 AM
link
Quote Just found out the DG834Gv5 has a Conexant CX94610 chipset, so if you want Broadcom best avoid this one
07-11-2008 11:30 AM
I might just keep on truckin' with this for the time being but revisit if it becomes an issue when it goes all 21CN round here.
Is it going to be possible to stay on an ADSL equivalent grade circuit if 2+ is too unstable? (James or other PN person)
07-11-2008 11:41 AM
Just ordered one from DSL source.
Hoping it'll sort things out as cant risk my home connection becoming unreliable, particularly as I'm hoping to be job hunting at end of next year when I get my networking quals.
Thanks for the info Jim and thanks for taking a look James
07-11-2008 11:47 AM
07-11-2008 11:49 AM
(This is certainly the case on my neighbour's BE line - he needed to manually change the setting in his router from ADSL to ADSL2+ to get speeds above 8Meg - he's not using their BEBox but a Draytek router.)
Edit: typo
07-11-2008 11:56 AM
Oh please bring on fibre to the home!
07-11-2008 12:03 PM
the DG834N I'm using now autodetects so couldn't force it down to ADSL 2 (I didn't want to use the O2 box when I was with them).
