Synch Speed reduced after fault resolution
- Synch Speed reduced after fault resolution
06-05-2008 3:17 PM
Now that I have reconnected today my synch is 6272Kbps and my Plusnet profile shows
Your High-speed Broadband Service
Your current broadband speed is 4000 Kbps
Plusnet turned interleaving on last Friday and I turned it back off again today. Am I likely to get my synch back to 8128 again and my profile back to 8000 Kbps? I have tried to reconnect my router several times only to synch at 6272 Kbps. I know that a synch of 8128 can't be obtained with interleaving on but I should still be getting a synch of 7.5MB and a throughput of at least 6500-7000 Kbps. Help please.
Re: Synch Speed down after fault resolution
06-05-2008 3:20 PM
From http://www.plus.net/support/broadband/troubleshooting/speed_faults.shtml
Quote If the speed of your connection has been lowered as the result of a temporarily fault on the line, once the fault is cleared, the speed of service will generally increase back to usual levels after a period of three days.
Re: Synch Speed reduced after fault resolution
06-05-2008 3:27 PM
I also noticed that my SNR is now 15.5, I hope this isn't fixed as it used to hover between 10.5 and 12. BT did a manual line test for me last Friday, I hope thay haven't fixed the SNR.
Link Information
Uptime: 0 days, 1:00:30
Modulation: G.DMT Annex A [POTS Overlay Mode]
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,272
Data Transferred (Sent/Received) [MB/MB]: 2.21 / 6.56
Output Power (Up/Down) [dBm]: 12.0 / 19.0
Line Attenuation (Up/Down) [dB]: 11.0 / 20.0
SN Margin (Up/Down) [dB]: 26.0 / 15.5
Vendor ID (Local/Remote): ALCB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
06-05-2008 4:11 PM
If BT have changed your target SNR value, then you are more than welcome to raise a fault to us and we can then get BT to lower it for you.
06-05-2008 5:11 PM
06-05-2008 5:44 PM
06-05-2008 11:13 PM
Uptime: 0 days, 3:33:05
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6,720
Data Transferred (Sent/Received) [MB/MB]: 4.27 / 11.29
07-05-2008 10:10 AM
Quote from: tywyn My router has synched at 6.7MB now for over 3.5 hours and my speed is still 131 kb/s and BRAS still stuck at 500 Kb/s (135 Kb/s in reality I think) I can't do anything apart from some slow surfing. The strange thing is my BRAS was 4000 kb/s this afternoon until I rebooted to get a better synch (which I did) but the BRAS went down to 135 kb/s, eventhough the connection is stable since I changed the modem cable. Can you fix my profile please? I really don't want to wait 3 days for the profile to (possibly) correct itself from 131 kb/s.
There was a sync event on your line yesterday of 160kbps at 12:46:44pm.
I'm afraid we're going to have to wait for BT's DLM kit to do it's thing, but if there's no change in a couple of days then let us know and we can revisit the situation and raise a fault if needs be.
07-05-2008 10:35 AM
Quote from: Bob
That's strange as I reconnected at about 1pm and my profile showed as 4000 Kbps all afternoon. I rebooted the router a couple of times hoping to get a better synch which I did at about 5pm but then my profile went to 135 kbps. I was even speed testing the line in the afternoon and I was getting about 3MB so it's strange how it synched at 12:46 at 160 kbps. The router hasn't dropped the connection once and the lowest I synched at yesterday was about 6.2mb. I haven't been able to use the service properly since last Thursday and now another two days on top. I'm hacked off that I can't play WoW more than anything. I'm paying to use both DSL and WoW and can use neither, apart from some 56k style browsing.
07-05-2008 11:20 AM
Quote from: tywyn That's strange as I reconnected at about 1pm and my profile showed as 4000 Kbps all afternoon ...
Where did you see this? The PN portal @ https://portal.plus.net/my.html?action=data_transfer_speed is only updated at 8AM and 8PM each day ... according to what we are told.
SW.
3Mb FTTC
07-05-2008 11:45 AM
Quote from: godsell4
SW.
I saw it in the PN portal. Here is a speed test result from 12:58 yesterday
So how could it synch at 12:46 at 160 kbps when I was able to get 2918 kbps at 12:58? I really think there's a problem with the profile, which needs to be reset.
I noticed that my router SNR had dropped to 13 today with a stable (as always) connection, so I rebooted (after 11.5 hours of error free connection) to see if the synch would improve but in fact it's gone from 6.7Mb to 6.0 MB and the SNR back up to 15 again.
07-05-2008 11:49 AM
07-05-2008 11:57 AM
Quote from: Jameseh If you had a blip on your sync speed (which may have lasted for a short period of time) it normally takes about 75-90 minutes for BT to drop your IP Profile.
Ah I understand. The 'blip' must have been when I was testing the faulty cable. It looks like a two day wait then, arggggghhhh I can't stand it, I'm going out
07-05-2008 1:21 PM
As you last re-synced when your SNR was 13db (ie. 2dB noiser line, which is why it dropped to 6M) you need to wait until your noise is better than 15dB, earlyish in the morning (in daylight) seems to be the most likely time when it should be consistently better, but see what your router is telling you. Personally I wouldn't try until your SNR is at least 15.5dB, preferably nearer 16 or more and check that it is fairly stable over several minutes.
What I do not know is how many re-sync's per hour (say), will be interpreted by BT's system as a fault, I've seen the question asked somewhere, but can't remember where and didn't see an answer; also what's the minimum time to be off-line to re-sync that won't be interpreted as a sync event. Perhaps someone with the definitive knowledge and experience could advise on that.
Best of luck anyway.
07-05-2008 1:54 PM
Quote from: Anotherone
What I do not know is how many re-sync's per hour (say), will be interpreted by BT's system as a fault, I've seen the question asked somewhere, but can't remember where and didn't see an answer ...
The consensus seem to be 10 resyncs in 1 hour will get your
SW.
Edit: Ooops. correct a typo.
3Mb FTTC
