Sync speed vs actual speed
- Sync speed vs actual speed
02-06-2014 8:34 PM
Can anyone suggest why, when my VDSL modem is showing the below connection stats, I am only able to
receive a maximum download rate (tested from various sites at various times, on a wired connection) of
~50Mbps down? (upload is a more reasonable 17 up)
If I am reading the below correctly I am syncing at a much higher speed than this...
[InternetGatewayDevice.WANDevice.1.WANDSLInterfaceConfig.Status] UP
[InternetGatewayDevice.WANDevice.1.WANDSLInterfaceConfig.ModulationType] VDSL
[InternetGatewayDevice.WANDevice.1.WANDSLInterfaceConfig.LineEncoding] DMT
[InternetGatewayDevice.WANDevice.1.WANDSLInterfaceConfig.DataPath] Fast
[InternetGatewayDevice.WANDevice.1.WANDSLInterfaceConfig.InterleaveDepth] 1
[InternetGatewayDevice.WANDevice.1.WANDSLInterfaceConfig.LineNumber] 1
[InternetGatewayDevice.WANDevice.1.WANDSLInterfaceConfig.UpstreamCurrRate] 20000000
[InternetGatewayDevice.WANDevice.1.WANDSLInterfaceConfig.DownstreamCurrRate] 80000000
[InternetGatewayDevice.WANDevice.1.WANDSLInterfaceConfig.UpstreamMaxRate] 37241152
[InternetGatewayDevice.WANDevice.1.WANDSLInterfaceConfig.DownstreamMaxRate] 104197984
[InternetGatewayDevice.WANDevice.1.WANDSLInterfaceConfig.UpstreamNoiseMargin] 183
[InternetGatewayDevice.WANDevice.1.WANDSLInterfaceConfig.DownstreamNoiseMargin] 102
[InternetGatewayDevice.WANDevice.1.WANDSLInterfaceConfig.UpstreamAttenuation] 0
[InternetGatewayDevice.WANDevice.1.WANDSLInterfaceConfig.DownstreamAttenuation] 137
[InternetGatewayDevice.WANDevice.1.WANDSLInterfaceConfig.UpstreamPower] 43
[InternetGatewayDevice.WANDevice.1.WANDSLInterfaceConfig.DownstreamPower] 102
Message 1 of 6
(1,500 Views)
5 REPLIES 5
Re: Sync speed vs actual speed
03-06-2014 9:19 AM
Hi dbrb2,
If you could PM me your account username, I'd be happy to take a look.
As a side note, are you doing speed tests via Wireless? If so, what speeds do you get via Ethernet?
Message 2 of 6
(919 Views)
03-06-2014 9:22 AM
Quote from: dbrb2 (tested from various sites at various times, on a wired connection)
Message 3 of 6
(919 Views)
03-06-2014 9:46 AM
Sorry, missed that - not a massive issue, I'm sure
Message 4 of 6
(919 Views)
03-06-2014 9:49 AM
Hi Chris - just PM you the username
Actually I think you checked this for me last week. I still haven't been able to try doing PPPoE directly (bypassing the router) as suggested - but thought posting the modem stats could be of use to see what was going on
Ben
Ben
Message 5 of 6
(919 Views)
03-06-2014 10:03 AM
Thanks Ben.
Made a note of that. Would you be able to do a PPPoE Connection to see if the speeds do increase? It will give us more assurances that it's not the router or any other part of the set up.
Message 6 of 6
(919 Views)
