Sync speed slow
- Sync speed slow
Sync speed slow
21-12-2015 12:05 PM
Hi everyone,
I've recently moved house and used a pre-installed phone extension inside the house which must have had a fault, as the noise reading and attenuation were poor (these have now improved since I stopped using this extension).
My issue now is that my max line speed is nowhere near my current sync speed.
I've tried restarting a couple of times over a couple of days, which hasn't solved it, and I have also spoken to someone from PlusNet who said if I restarted in a few hours it would improve the sync speed, which hasn't worked.
I know the line is capable of more than what I'm currently getting, as I was getting a much better reading in the middle of last week.
Here's the current stats from our router:
Line Status: Connected
DSL Modulation Type: ADSL_2plus
Annex Type: Annex A/L
Upstream / Downstream
Current Rate (Kbps): 1108 / 2268
Max Rate (Kbps): 1108 / 12508
SNR Margin (dB): 6.7 / 16.4
Line Attenuation (dB): 13.5 / 33.4
Errors (Pkts): 0 / 0
Any help would be much appreciated!
Message 1 of 2
(634 Views)
1 REPLY 1
Re: Sync speed slow
21-12-2015 2:44 PM
It looks like you're now back in sync at 15Mb/s, so you should be seeing much improved speeds.
Message 2 of 2
(360 Views)
