Sync speed same after fibre install
Nokk
Hi
I have had my fibre installed today however i'm still sync'd at 6.5mb (my adsl speed)please can you check my profile. I should be getting close to 80mb
Many Thanks
Nokk
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Sync speed same after fibre install
Hi Nokk,
Really sorry about that. Could you restart your router and see if the profile change I've made has made a difference for you?
Chris Pettitt
Cloud Environments Engineer
Nokk
Hi Chris
Thanks - I have run a few speed tests and there are improvements averaging 25-30mb now, still well down on 80mb though
Nokk
Plusnet Staff
Plusnet Staff
Fixes: 5
Can you connect with an Ethernet Cable and re-run the speed tests please?
Wireless Speeds aren't a very good indication of how your line is performing.
Chris Pettitt
Nokk
Hi Chris
good news - Wired up i now get 74mb down and 17mb up  - thats not bad  Smiley
Thanks for your help
Nokk
Plusnet Staff
Plusnet Staff
Fixes: 5
Woohoo Smiley
Chris Pettitt
