Sync speed difference between router and Plusnet website
- Sync speed difference between router and Plusnet w...
13-09-2011 7:51 PM
Hi
My router reports a speed of 5504 kbps - but https://portal.plus.net/my.html?action=data_transfer_speed is saying 7.15 Mb.
No problem really just wondered why this is.
Message 1 of 5
(916 Views)
4 REPLIES 4
Re: Sync speed difference between router and Plusnet website
13-09-2011 10:38 PM
Your router may have done a recent resync to the lower speed and the Plusnet system has not caught up yet.
It may be useful to check your profile here http://speedtester.bt.com/
Derek
Derek
Message 2 of 5
(499 Views)
14-09-2011 10:46 AM
Hi ajsvoice,
It's because with your line only being activated yesterday we set the IP profile on our system to the maximum until it's changed by the DLM. This is normal practice. Your Profile is 4000 on BT at the moment so ours will reflect that soon. It could be possible to get that a little higher, but I'm not sure how you've got your kit set up. If you are using extension sockets/cables, this can cause slower speeds.
Jojo
Jojo
Message 3 of 5
(499 Views)
14-09-2011 12:54 PM
Thanks no worries - it's a long line here so 4000/5000 is about normal. Guess the profile will rise if it stays stable for long enough.
Message 4 of 5
(499 Views)
14-09-2011 1:03 PM
Hi ajsvoice,
Probably, your current 5504k will give you a profile of 4500 and if it goes over 5696K it'll go to 5000.
Jojo
Welcome to Plusnet and the forums, by the way!
Quote Guess the profile will rise if it stays stable for long enough.
Jojo
Message 5 of 5
(499 Views)
