Sync rate woes!
- Sync rate woes!
Sync rate woes!
27-02-2008 9:08 PM
I have been having connection and speed problems since I migrated to plus about a month ago. To cut a very long story (ticket) short, I believe that my router is at fault, or at least not compatible for some reason! As such, I changed my modem to a simple usb modem and now I appear to be flying! However, my sync rate is still at 500kbps. Having had a reliable, stable connection for nearly 20 hours now, at 4.4mbps, is there any chance you could change my sync rate so that I can see if my woes are truly over, and throw the netgear router in the bin!
Regards
Dan
Re: Sync rate woes!
27-02-2008 9:20 PM
What does www.speedtester.bt.com say?
Re: Sync rate woes!
27-02-2008 9:44 PM
The results from speedtest do show that my line is definitely capable of more!
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 250 kbps
DSL connection rate: 448 kbps(UP-STREAM) 4416 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 215 kbps
If you wish to discuss these results please contact your ISP.
Hope I re sync soon
Re: Sync rate woes!
28-02-2008 10:37 AM
Looking at BTs IP Profiling reports, I'd expect your profile to be lifted at some stage tomorrow.
Re: Sync rate woes!
28-02-2008 12:16 PM
I know this is a stupid question but i'm gonna ask it anyway!
As I am now connected with my usb modem, does this mean that I have to keep my pc on at all times now in order to keep my sync rate and IP profile up?
Re: Sync rate woes!
28-02-2008 12:26 PM
Now you have proved that your problem was due to your router I'd seriously suggest investing in a new router. You might see even better speeds.
Re: Sync rate woes!
28-02-2008 12:38 PM
Re: Sync rate woes!
29-02-2008 12:33 PM
Am puzzled! I ordered a BT 2110 Voyager router but the 1800HG has been delivered instead! I have definately been charged for the voyager! Whats the difference, price / performance, + am I due some kind of refund? Havent raised a ticket yet because I dont have time, (I should be back at work now!), but I will check forum when I return home before raising a ticket.
Re: Sync rate woes!
29-02-2008 1:22 PM
Re: Sync rate woes!
29-02-2008 2:16 PM
Due to stock issues, we've been shipping out the HG1800 instead of the 2110.
The 2110 is also due to be removed (along with the whole Voyager line) in a months time.
Re: Sync rate woes!
29-02-2008 4:03 PM
