Sync problem
- Re: Sync problem
Sync problem
24-07-2008 4:58 PM
Does anyone know roughly how long it takes to fix sync errors
My ticket has been passed to BOT - DSL Logged Faults whoever they may be, but in the meantime I'm stuck on dialup?!
Ta
cp:red Please don't post titles in all CAPS. link:rules mod:end
Re: SYNC PROBLEM
24-07-2008 5:08 PM
It really does depend on what the problem is. There are a wide variety of issues that can cause a line to drop sync and I'm afraid I really couldn't say how long it would actually take to fix, but we'll do our best to get it fixed for you as quickly as we can.
Re: Sync problem
01-08-2008 4:42 PM
Still not resolved - help!
Re: Sync problem
01-08-2008 6:19 PM
Re: Sync problem
04-08-2008 1:32 PM
Re: Sync problem
05-08-2008 3:30 AM
Just another thought, is your dial-up modem plugged in via a filter and all other phones/skybox or whatever also plugged into filters.
If you've gone through all that, could you borrow a router from one of the neighbours to see if you get the same results (don't forget you'll need to put your own login details in and remember to remove them after!).
Hopefully Jameseh from PN will pick this up in the morning.
Regards.
Re: Sync problem
05-08-2008 6:39 AM
I'm sorry it's taking so long to get your fault fixed. Having looked at your fault notes I can see that this has been (re)raised with BT Wholesale no less than 5 times! As you're aware, you've also had an engineer visit.
We'll keep on pushing this for you and rest assured it will get fixed. I'm sure we'll be able to refund you for the lost service once things are back up and running.
In the meantime I notice you mention that you're using dial-up - Is this the free dial-up number that we gave to you? I wouldn't want you to be paying any more than you need to.
Re: Sync problem
06-08-2008 9:13 AM
Its now been 2 weeks since I should've been connected - any help would be appreciated!
Re: Sync problem
06-08-2008 11:01 AM
As previously mentioned faults can get complex and take a while to resolve but after looking into your case the information we are getting from our supplier is that the fault was confirmed resolved with you which after your discussion with a faults analyst today was i see this was not the case. I am not happy with this response and therefore have escalated this for you and can see that another engineer has been arranged for tomorrow morning.
We will look at this again in the morning following the visit.
