Sync @ high 6Ks low 7Ks
- Sync @ high 6Ks low 7Ks
26-05-2009 5:56 PM
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed:
5500
A while ago the speed was in bold, and for some time now, over 2 months, sync has been in the region shown in title. Today it was 7072.
Shouldn't my profile be higher than that shown?
Re: Sync @ high 6Ks low 7Ks
26-05-2009 9:37 PM
You need to keep your synch for 3 days to raise you profile.
26-05-2009 11:07 PM
27-05-2009 7:01 AM
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 7072 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 5500 kbps
Actual IP throughput achieved during the test was - 4867 kbps
An aside question. The test I used last evening brought up a second test that I could not see how to use: this morning's did not. What is test 2 used for, when is it required?
27-05-2009 10:21 AM
Your current sync speed should give you an IP Profile of 6000Kbps, which I expect will pick up in the next couple of days.
27-05-2009 10:44 AM
27-05-2009 10:55 AM
Yes - I think your reconnecting over the weekend probably resulting in a *slightly* lower sync event, causing the profile to drop to 5500Kbps. Should pick up again soon though.
27-05-2009 11:08 AM
27-05-2009 11:59 AM
Conversely, if you have a lower sync that would put you on a lower profile, this will happen within 75 minutes. Unfortunately this is the way the exchange DLM works!
PN profiles usually catch up BT's within 12 hours. Sometimes either can get "stuck", doesn't happen too often though.
28-05-2009 9:48 AM
I'm still @ 5500 profile and the BT test a couple of minutes back had d/load 4809. However the tester recommended by PN gave this series of results
Today 09:42 6067 kbps (758kB/s)
Today 09:27 6548 kbps (819kB/s)
Today 09:26 6156 kbps (770kB/s)
I'm perplexed: I can only think the recommended one is broke. Is there another explanation
28-05-2009 9:54 AM
28-05-2009 10:07 AM
28-05-2009 10:11 AM
28-05-2009 4:15 PM
, as I was out choral rehearsing
28-05-2009 4:45 PM
Quote from: Jameseh Nope, it's broken, but it only seems to be broken for you!
Is that different breakage from this then? http://community.plus.net/forum/index.php/topic,76678.msg616340.html
