Sync drops when phone rings (subject was "Is this a record?)
- Sync drops when phone rings (subject was "Is this ...
Re: Sync drops when phone rings (subject was "Is this a record?)
26-04-2013 6:02 PM
Looks like it's time for some serious thinking! Money isn't the only consideration - it's the response if you have an issue that is just as important!
26-04-2013 6:10 PM
Edit: I expect the ISP you are talking about wants a lot of money for Unlimited, if they do it! I know they don't like OR/BTw
26-04-2013 6:49 PM
26-04-2013 7:05 PM
26-04-2013 7:16 PM
Quote from: Anotherone I presume you've responded to the ticket and stated that <removed> CSC Analyst doesn't know what he's talking about
Oh yes, I gave quite a 'robust' reply to that ticket!
They don't do unlimited, but as my monthly usage is usually 20-30GB they have a package that would suit me nicely.
29-04-2013 11:50 AM
Chris Pettitt has been working along with Mark to see about getting a TPM and L+S to a different port, we're just waiting to hear back on this.
29-04-2013 12:47 PM
The first question has to be are there any non-Marconi DSLAMs in the exchange - if so you have to insist that the TPM and L+S is on to a non-Marconi port.
29-04-2013 12:51 PM
Quote from: jelv If the different port is still on a Maconi DSLAM it won't make any difference!
I'm not sure you can drawn that conclusion as it could be your current port has gone faulty, not the whole card.
29-04-2013 1:03 PM
I've had it confirmed that it is a known fault with Marconi DSLAMs from two different sources.
29-04-2013 1:18 PM
29-04-2013 1:36 PM
If the only equipment at the exchange is 'Maconi' I see very little that we can do. I'm not sure what any other ISP can do in that position either.
29-04-2013 1:40 PM
For an ISP not to be able to provide a customer with a reliable service because of substandard BT hardware is really not acceptable.
08-05-2013 11:24 AM
Overnight I've had Max Premium removed from my line and dropped back to standard Max - from a couple of quick tests things are looking a lot better - the connection did not drop with an incoming call. For the second test I had an iPlayer download running - previously that would have caused the connection to drop very quickly when there was an incoming call.
One thing I do need is an SNR reset to put my target noise margin back to 6 (it's currently 9).
08-05-2013 11:47 AM
08-05-2013 12:34 PM
Hopefully moving to MAX may help, I appreciate your frustration with this but our faults team have continually pushed this back in an attempt to resolve this, however it does appear that there will be no new DSLAM fitted at the moment.
