Sync drop
- Sync drop
Sync drop
05-10-2010 2:41 PM
I'm pretty sure my connection sync speed has dropped recently and therefore my profile and speed. It used to sync at 20000Kbps but since for the last week or so (since the 21CN problems plus.net was having) is now only 18000Kbps.
I also noticed my SNR margin has gone up from 3-6db to 9db.
Is there anything i or plus.net can check?
Message 1 of 9
(9,288 Views)
8 REPLIES 8
Re: Sync drop
05-10-2010 6:04 PM
Message 2 of 9
(503 Views)
Re: Sync drop
05-10-2010 6:21 PM
I thought i did yes. I only live 2 minute walk from the exchange. I could be lying though.
If the sync speed hasn't dropped the general line speed has. Looking at my speedtest.net results i generally use to get a 21ms latency with a 16.5Mb/s download speed. Now its showing between 77-100ms latency and only 13Mb/s download speed using the same servers. I will try again when its not peak time to make sure.
Just used the plus.net speed checker and its bouncing around all over the place.
Today 18:17 14149 kbps (1.77MB/s) 762 kbps (95.3kB/s) Share
Today 18:16 3504 kbps (438kB/s) 766 kbps (95.8kB/s) Share
Today 18:15 14041 kbps (1.76MB/s) 766 kbps (95.8kB/s) Share
Today 18:15 11984 kbps (1.5MB/s) 761 kbps (95.1kB/s) Share
Today 18:14 9655 kbps (1.21MB/s) 758 kbps (94.8kB/s) Share
Today 18:13 645 kbps (80.6kB/s) 705 kbps (88.1kB/s) Share
Message 3 of 9
(503 Views)
Re: Sync drop
05-10-2010 6:23 PM
Actually, if you look at this thread by me, my sync speed was 20568Kbps. Albeit this is a little while ago
http://community.plus.net/forum/index.php/topic,82635.msg679369.html#msg679369
Message 4 of 9
(503 Views)
Re: Sync drop
06-10-2010 7:58 AM
Just ran another speedtest. Speed still slower and ping is awful
http://www.speedtest.net/result/979841206.png
Message 5 of 9
(503 Views)
Re: Sync drop
06-10-2010 8:52 AM
Hi Zebbedi
Are you getting packet loss when trying to ping things?
Message 6 of 9
(503 Views)
Re: Sync drop
06-10-2010 11:09 AM
Tried pinging various different services... doesn't seem like any packet loss.
Just did another speedtest. Even worse!
http://www.speedtest.net/result/979959246.png
Message 7 of 9
(503 Views)
Re: Sync drop
08-10-2010 5:10 PM
Hi zebbedi,
I've just run some line diagnostics and the line speeds you reported in this post seem to match up with what's on my line tests so this could be a poor performance fault.
Could you please raise this via our fault checker?
https://faults.plus.net/applications.php?Module=Faults
Message 8 of 9
(503 Views)
Re: Sync drop
14-10-2010 10:54 AM
Message 9 of 9
(503 Views)
