Sync Speed
- Sync Speed
Sync Speed
16-06-2010 9:06 PM
The estimated line speed on the plus site is 12mb.
My router sync speed to staying around 9000, although it has been as much as 9600 and low as 7000. Upstream is very good at 1000
does this sound reasonable, or should it be nearer to the estimate? The previous estimate of 6mb for upto 8mb was very accurate.
I have tried the master socket, with no noticable improvement.
Below is some further information.
Thanks in advance for your help.
Justin
--- DSL Information ---
DSL Driver Version: AnnexA version - A2pB023k.d21d
DSL VPI/VCI: 0/38
DSL Status: Showtime
DSL Mode: ADSL2+
DSL Channel:
DSL Upstream Rate: 1062 Kbps
DSL Downstream Rate: 8931 Kbps
Down up
DSL Noise Margin: 4.4 dB 5.4 dB
DSL Attenuation: 42.5 dB 21.1 dB
DSL Transmit Power: 0.0 dBm 12.9 dBm
Download speedachieved during the test was - 7950 Kbps
For your connection, the acceptable range of speedsis 1000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :8931 Kbps(DOWN-STREAM), 1061 Kbps(UP-STREAM)
IP Profile for your line is - 8000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 17.13:26.14:56.73 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
Justin
DSL VPI/VCI: 0/38
DSL Mode: ADSL2+
DSL Channel:
Down up
Message 1 of 4
(703 Views)
3 REPLIES 3
Re: Sync Speed
16-06-2010 9:11 PM
Putting your attenuation in here http://www.kitz.co.uk/adsl/max_speed_calc.php tells me you are doing pretty well as that gives 8288kbps
Message 2 of 4
(347 Views)
Re: Sync Speed
16-06-2010 9:15 PM
probably pretty good for the attenuation, hence distance in copper to your exchange
have a look at samknows exchange search / checker
http://www.samknows.com/broadband/checker2.php?p=btadsl
or kitz's similar
http://www.kitz.co.uk/adsl/adslchecker.php
t.
or kitz's similar
t.
Message 3 of 4
(347 Views)
Re: Sync Speed
17-06-2010 4:09 PM
Looks like I will have to stick with it and see if things improve. The speed is better than the ADSL1 connection, so that's good. Just a little disappointed that the estimate is off by 25%. We all want more speed, even if we don't really need it.
Message 4 of 4
(347 Views)
